Old 05-21-2013, 01:15 PM   #1
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
Exclamation aem EMS-4 standalone ECU
Hi guys, next step in my project is running a standalone ecu (currently using aem FI/c). I would like to use the aem EMS, but I am not sure of some compatibilities with my 1NZFE...
Sensors that I know EMS will support/run easely (correct if Im wrong);
1.Mag crank sensor (already work with FIC, why not)
2.Mag cam sensor (already work with FIC, why not)
3. 370cc deatschwerks injector, 12.2ohm high impedance so why not.
4.Coolant temp, I will use aem unit...
5.Air temp, I will use aem unit...
6.Throttle position sensor (already work with FIC, why not)
Sensors that I am not sure to be able to run;
1.My oem 1nzfe ''coil on top''??
2.My idle air control valve with 3wires on the TB??
3.Could I just use my aem wideband O2 sensor or I still need the original one?
4.Knocksensor??
Also there is 2 kind of wiring kit you can buy, first is a small one with no relay, second is a big one with relay & fuses... Which one I would need? Probably the big one since I dont know how I could still use the stock fuse/relay box.
Thanks big time, and I know most of you guys run Yaris, so you may not answer my question about the idle air control valve (TB is dif from echo)... But thanks for help anyways!
maxthehax is offline   Reply With Quote
Old 05-21-2013, 01:47 PM   #2
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
I think Jason@SportsCar is using an EMS as well, you should PM him
Ryze268 is offline   Reply With Quote
Old 05-21-2013, 02:14 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
So is Garm from MicroImageonline.com
-Derrick-
Old 05-21-2013, 03:05 PM   #4
maxthehax
maxthehax's Avatar
Thanks! Is that his yarisworld username??
Yes he does, he is not using stock coil though, I think he used honda coil ignition...
Old 05-21-2013, 03:12 PM   #5
Jason@SportsCar
4.Knocksensor??
I use the EMS 2. But it is sort of a hybrid install, I still have the stock ECU to run the drive by wire throttle body.
I am using nearly all OE sensors, along with OE coils and injectors. However, the factory MAF is now used only for air inlet temp because we are using an AEM MAP sensor. We are also using the AEM wide-band O2, the stock O2 is gone.
Old 05-21-2013, 04:18 PM   #6
maxthehax
maxthehax's Avatar
Smile
Okai so if you are still using the stock ECM to run your drive by wire TB, this is because the EMS cannot by itself?? I have an 2005 echo, so my TB is the drive by wire...
Is there any other reason for you to keep the stock ecu installed?
Thanks very much for your fast informations!
Also, what about the wiring kit needed? Do you guys used the big 96'' with the relays & fuses?
Old 05-21-2013, 04:46 PM   #7
Jason@SportsCar
The EMS 2 can not run the DBW. The new AEM Infinity is supposed to, but they only have limited applications so far.
Old 05-21-2013, 03:31 PM   #8
Same here.
Old 05-21-2013, 06:48 PM   #9
converting to cable throttle was not that difficult. We sourced xB pedal, cable and hooked it up to a Celiga GT-S throttle body.
You will need your stock ECU for power steering if you're keeping that. (I know there's a power steering ECU, but the main unit must be present.
Old 05-21-2013, 08:52 PM   #10
ilikerice
ilikerice's Avatar
OH WHAT THE HELL?
I was gonna go with the EMS and the plug in play harness so I can stay in STF for the rest of the year or until I go turbo.. But if I have to swap the throttle body out and run cable that will throw me into FSP.. son of a monkey!
Thanks for this OP.. thanks alot!
good info here.
-Derrick-
Old 05-21-2013, 10:36 PM   #11
Focus_Sh1ft
Focus_Sh1ft's Avatar
Wow, I'm really surprised. That seems like a huge oversight.
What's the drawbacks of not having control over the throttle with the ems? I can't think of any outside of idle control...
Old 05-22-2013, 01:48 AM   #12
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
I think a plug and play harness are being made for the Yaris now. The AEM can control or read OE sensor's. The purpose of keeping the stock ECU is to control DBW and A/C. My suggestion would be to talk with your tuner he will know what you will need to do.
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 05-22-2013, 05:08 PM   #13
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
there is an ems 4 pnp
http://www.treadstoneperformance.com...6-2013+BF14049
Old 05-22-2013, 07:04 PM   #14
ilikerice
ilikerice's Avatar
why is one $100 cheaper than the other and what is the difference?
Eh. I guess if one was ready to purchase they could easily call and find out.
-Derrick-
Old 05-22-2013, 07:07 PM   #15
ilikerice
ilikerice's Avatar
so, what can this do that the EMS 2 can or can not do?
http://www.treadstoneperformance.com...+EMS+4+30-6905
This is much cheaper, is this a piggy back? All new to me
-Derrick-
Old 05-22-2013, 07:26 PM   #16
Yoda
Yoda's Avatar
Its a stripped down version of the series 2. No bells and whistles, no two step, only supports 4 injectors and 4 coils cant remember the rest. Check the AEM forums. I was going to get it but got the Haltech Sprint 500 instead.
Old 05-22-2013, 08:34 PM   #17
Radou
Radou's Avatar
Drives: yaris 09 ncp91
boomslang made a pnp harness for 499$ http://www.boomslang.us/aem-ems-4.php
Radou is offline   Reply With Quote
Old 05-23-2013, 09:24 AM   #18
maxthehax
maxthehax's Avatar
I dont have any power steering :P Car is base, didnt come with it!
OMG I made a big mistake by saying that I had a DBW hahahaha I have a drive by CABLE...
Cable and wire were the same thing in my head :P sorry
So I thank you guys, you answered all my question about the ability to run all sensors / TB, since I have a DBC I should have no prob.
But what about the wiring harness I need!? :P
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
New Engine Management System offered for the 1NZFE Dezod Forced Induction Forum 51 06-16-2011 10:33 AM
Standalone ECU d1nzfe Performance Modifications 11 12-24-2009 11:46 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
