Old 11-20-2011, 03:26 PM   #1
vrwm
vrwm's Avatar
Drives: 2012 Super White Yaris SE
DIY: 2012 Front Bumper Removal
1st step in a couple of DIY's I have being written up.
All you need is a 10mm socket and ratchet and a flat head screw driver.
Pop Hood and Remove front clips(7 clips)(By the Yellow Dots)
Remove Clips using flat head screw driver or other pry tool to pull up on center piece, then pull the whole clip out.
Remove Bottom bumper screws and bolts. 10mm socket and ratchet used.(by the yellow dots aproximately)
Sorry for the bad picture. I'll get a better one when I do my break in oil change.
Now bumper should be loose, on both wheel wells there are retaining nubs. Pull back on the bumper a little by the yellow dot and it should break free.
Now pull the bumper off, there are more retaining nubs under both head lights. There are no more screws or bolts. Just give it a gentle tug and it will come off.
If you have an SE Remove foglight bulbs, or just loosen the connector. It will be the last thing connected to the bumper.
TADA!!
vrwm is offline   Reply With Quote
Old 11-20-2011, 05:23 PM   #2
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
Nice DIY for the 2012 model, good pictures.
Looks like it's slightly different that the earlier models.
Is the hood seal across the top of the bumper cover a factory item or did you add that?
Stove is offline   Reply With Quote
Old 11-20-2011, 05:37 PM   #3
Klink10
Klink10's Avatar
That hood seal is a factory item. One thing I noticed when looking at it a couple of weeks ago.
Old 01-24-2012, 10:09 AM   #4
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
ordered one from toyota BUT ETA is 2/23/2012 and it was ordered back in NOV.
Old 03-23-2013, 05:23 PM   #5
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
can get i replacement front bumper from this website? http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388
DJYojimbo is offline   Reply With Quote
Old 11-20-2011, 06:58 PM   #6
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Nice DIY!
Old 11-21-2011, 08:26 AM   #7
Gotta ask what it is you are doing which requires bumper removal so early in ownership.
Old 11-21-2011, 11:37 AM   #8
vrwm
vrwm's Avatar
Piaa Sports horns and HID fogs. Couldn't deal with the Meep Meep!!! I wanted HONK!!! lol
Old 11-21-2011, 11:20 PM   #9
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
no hella supertones? have them on the echo, yay for 118db!
Old 03-22-2013, 09:45 AM   #10
Eren_13
Eren_13's Avatar
Drives: Yaris SR '12
I know this is a pretty old thread but great DIY, thanks for posting. Just what I was looking for as I'm thinking of doing the same as you and fitting HID fogs :) you got any photos of them installed??
Eren_13 is offline   Reply With Quote
Old 03-22-2013, 07:34 PM   #11
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
One add to this, you dont need to remove the whole bumper. Just the top.
The bumper will pivot down.
I installed fog lights, and PIAA horns without removing the bumper completely.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 03-22-2013, 09:34 PM   #12
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
are the horns plug and play?
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-23-2013, 11:32 AM   #13
Absolutely Red 12
Asshole
If you see the picture in the OP, there are 3 holes on the top of the crash bar, use the outer holes.
Using 2 body bolts, and 2 "U" spring nuts on the holes.
Some bolt it to the upper radiator support, where they can be seen through the grill.
Mine are below the grill.
The wiring needs to be extended by using a female spade connector (to the existing loom) crimped to two wires, splitting to one male spade connector to each horn.
The existing horn fuse and relay handle it.
I used the higher toned ones, they come as a pair:
http://www.amazon.com/85110-115db-40...rds=piaa+horns
These are lower tone:
http://www.amazon.com/85112-115db-50...rds=piaa+horns
Old 03-23-2013, 02:59 PM   #14
Shroomster
Shroomster's Avatar
thanks!
Old 03-24-2013, 08:55 AM   #15
Eren_13
Eren_13's Avatar
I was wondering if the HIDs could be installed without taking the bunker completely off. If the fog light housing unclipped at all while its still attached to the bumper?
Old 07-19-2013, 05:23 AM   #16
arose62
Drives: yaris
Just started on my horn enhancement project - planning to use the air horns I had in my very first car (about 35 years ago!), as I just found them in the shed.
First thing I noted on my 2013 Yaris is that the 10mm fasteners at the bottom of the bumper are not all the same. Some are screws, which go into a clip-in plastic block, and others are bolts which thread into metal. And the pattern is not symetrical, so take notes, or pictures as you go, or just check that the fastener goes happily into the current hole.
Cheers,
Andrew
arose62 is offline   Reply With Quote
new front bumper spoiler and mags nazier Cosmetic Modifications (Exterior/Interior) 3 07-24-2010 09:35 AM
FS: KavinT Manseth Kit (Front Bumper Damage) LIMITED TIME PRICE! Treyz Items for Sale by private party 7 07-20-2010 03:57 PM
New mod: half silver front bumper paint job! SAV912 Photo-Video-Media Gallery 9 07-18-2010 12:57 AM
FS: KavinT Manseth Kit (Front Bumper Damage) LIMITED TIME PRICE! Treyz Items for Sale by private party 3 05-26-2010 08:43 PM
