PEEWEE1
Drives: 2009 yaris s sedan Join Date: Apr 2013
re-learning ecm?
Am I to understand that there is a way to make my ecm (the cars computer) re learn my driving habits? My 2009 Yaris S is a used vehicle and I have no idea how it was driven by the previous owner. I would like to have my car react to my habits not some lead foot!!!
The ECM can be made to re-learn the short term fuel trims, by simply disconnecting the negative battery terminal for a couple of minutes. As far as re-learning shifting patterns relative to your driving style - That requires resetting the automatic transmission control within the ECM via the Toyota TechStream tool. I did that on my 09 about two weeks after I installed my Blitz Supercharger and noticed that once I did so the tranny shift points seemed better relative to the extra boost from the S/C.
#3 | |
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
To some extent yes. If you reset the ECM's tranny control and then drive it like you stole it the ECM should learn that shifting behavior.
I see... I wonder if is it possible to individually set each gear shift point using the techstream tool? or the minimum speed for cruise control?
No
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
curious question CTScott, is it good for a manual tranny? I drive normally, but because of inconsistent fuel economy figures sometimes on a drive it like a stole it manner (some nights/highway).
I still can't figure out the best shifting points that will keep fuel economy figures high. the manual states the best shift points but they're usually on 3k rpm point. are those accurate? or should i unplug the negative terminal then drive normal 100% (or for most of the time)? |
#8 | |
oh i see. so i guess it's the inconsistent city traffic that i don't notice anymore (been living and driving in the city for more than a decade). sigh.
thanks a bunch scott! i wish there was a filipino version of you here. :) |
| DIY - How to remove or insert a pin on the ECM Connector A21 | CTScott | DIY / Maintenance / Service | 6 | 05-21-2024 12:29 PM |
| WTB: ECM connectors(car side) + ECM male connector(ECM side) | mazilla | Willing to Buy by private party | 5 | 10-03-2011 09:25 PM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 03:54 PM |
| ecm controller | yaris9876 | DIY / Maintenance / Service | 0 | 05-26-2010 08:06 PM |
| Yaris has a learning ecu? | YogiYaris | Performance Modifications | 9 | 05-30-2007 07:03 PM |
