Old 02-05-2014, 02:07 PM   #1
Rutherford
Drives: 2008 Yaris
New question evap canister replacement
Ignore my old thread below as I have updated it.
Bought me a used evap canister and installed it. Thanks so much for the help with the connections. Was not difficult once I knew how to get them apart. After about 180 miles my check engine light came on and I went by Advanced Auto to see what code had come up. It read a small evap leak. I reset it and drove another 300 miles and the check engine came on again, same code P0456 small evap leak. I also still have a problem where I cannot pump gas very fast when I fill it up. It seems like it is not able to relieve the air as quick as I am putting the gas in. When I took the old evap canister off I checked the filter box? in the line from the evap canister to the filler neck. I did not remove it but I disconnected both lines leading into it and attached some tubing so I could blow through from each direction to make sure there was no water in it. I shook it and did not hear anything. Did not see any moisture but it seemed like there was some restriction in it. I figure it may only pass air/fumes in one direction but it was difficult to get air through either way. Could this cause the problem with not being able to pump gas at a normal rate or may I still have an issue with the evap canister? It did pass the emission test here in NC when the light was off.
Rutherford is offline   Reply With Quote
Old 02-05-2014, 02:46 PM   #2
The air vent pipe that goes to the filler neck should pass air without a problem in both directions. If is does not, their may be a spider web or something like that partially blocking it.
Old 02-06-2014, 01:01 PM   #3
Rutherford
Drives: 2008 Yaris
Thanks!
Must be a big spiderSeems like alot of restriction in that little plastic box. I have a real problem with mice but I don't know how he would got in there. The little beggers have chewed every wire on my ignition switch for my kawasaki mule. I finally wrapped the wiring harness with double sided tape coated with black pepper. They don't like thatThansk for the help!
Old 02-06-2014, 01:16 PM   #4
Originally Posted by Rutherford View Post
Thanks!
Do you park your Yaris outside? While rebuilding my latest Yaris, I figured out exactly how mice can get into a Yaris (nothing to do with the evap system, but a way that they can get into the cabin).
Need help with Evap Canister Replacement Rutherford DIY / Maintenance / Service 8 02-04-2014 10:59 AM
EVAP canister Jason@SportsCar Items for Sale by private party 5 04-11-2012 01:04 PM
replacement bulb question justinparadise21 Cosmetic Modifications (Exterior/Interior) 2 11-06-2008 01:52 AM
