Old 11-04-2008, 10:38 PM   #1
justinparadise21
Drives: 07 sedan aka black beauty
replacement bulb question
i did read the write up but my question is if i replace the bulb with a higher watts, will it affect anything besides possibly the wiring harness and the fuses cuz i replaced the 55w with a 80w bulb...will i have any problems???
thanks in advance
justinparadise21 is offline   Reply With Quote
Old 11-05-2008, 09:54 PM   #2
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Yes you might have an issue with melted Harness and burnt fuses but other user should more about it.
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 11-06-2008, 01:52 AM   #3
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
yeah, you may have a issue...I have been working at auto shops for almost 10 years now, and I have seen in happen numerous times, esp headlights.
if the watts are close, you shouldnt have issues, not to say you never will. for example to get rid of the yellow look on my white car the lisence plate lights gave off I switched the bulbs and they are 1w higher on each. I most likely wont ever have a issue, but there is always a chance of it.
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
Accessory Bulb Types, anyone know? Ayka Cosmetic Modifications (Exterior/Interior) 135 04-29-2007 08:33 AM
Exterior LED bulb Replacement & Tint ||)) (o) ||\|| Cosmetic Modifications (Exterior/Interior) 2 04-27-2007 05:45 PM
Bulb size (application) question. W.A.S.P Cosmetic Modifications (Exterior/Interior) 4 10-01-2006 02:21 AM
