Old 02-24-2014, 02:35 PM   #1
evastears
Drives: Yaris Verso
Vibration or buzzing brake while breaking
Vibration or Buzzing under brake while breaking on 2004 yaris
When i bought that car around 6-7 months ago, the pads and brake rotors were almost finished. And when i braked the steering wheel was shaking a lot together with the brake. Than i have changed the pads and rotors. By now everything had been perfect, didn't have any buzzing.
Lately the vibrations has started while breaking. While driving in high speeds, if i brake than i feel the vibrations. Today i was in a local repairer. He checked all the break systems and he said everything looks as it should be. He didn't have any clue.
But we are pretty sure the problem is about breaking system. And as i just mentioned i had just the same problem before. But after changing the pads and rotors it was fixed.
So what do you guys think ? Should i go to see a toyota guy or is it possible to DIY ?
Thanks
evastears is offline   Reply With Quote
Old 02-24-2014, 02:46 PM   #2
It may simply be that your new rotors are a bit warped already. If the new pads were not properly "bedded-in" then it is very easy under heavy braking to warp them. Here is an article on bed-in:
http://www.tirerack.com/brakes/tech/....jsp?techid=85
Old 02-24-2014, 02:50 PM   #3
Here's another interesting read that says that rotors really don't warp, but rather get uneven deposits from the pads:
http://www.stoptech.com/technical-su...nd-other-myths
Old 02-24-2014, 07:34 PM   #4
bairjo
That is a good write up with useful information....thanks for posting.
Old 02-25-2014, 01:40 PM   #5
evastears
Drives: Yaris Verso
Very useful and interesting information. Thank you. I will be checking and searching more.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
