Old 04-01-2014, 10:26 AM   #1
Rutherford
Drives: 2008 Yaris
252,000 Miles on Yaris - wierd noise
My 08 with automatic trans. is beginning to make a whining noise only during acceleration. Started about 2 months ago and it is getting a bit louder but still not real bad. The car only has 252,000 miles on it so I can’t image anything being wrong. Don’t know if the noise is trannie related but after doing some pretty healthy research on transmission fluid changes for these cars (dealer lifetime stuff)a few years back I opted to leave the original fluid in. I know this statement could probably start a healthy thread on its own but maybe we should consider my Yaris a test subject. I live in western North Carolina in the mountains and commute 180 miles a day to work, most of it highway except for 8 miles of the 180. These 8 miles are hard core steep gravel road not fit for most regular 2 wheel drive vehicles. The road gains about 1500 feet in elevation most of it in the first 1.5 miles. When going down this road I gear the car down to help the brakes. So with all that said the ole Yar has done very good. The fluid is still red but not as bright as new getting some light brown to it. It does not have a burnt smell to it but it also does not have the good ole “fresh” smell either. The Yar fits my needs well so I would like to keep her for another 250,000 miles, engine still purrs and she has enough war wounds to scare the Camry’s out of my way. Anyway I kept the radio off yesterday to follow the noise. It seems to not make any noise up until I get to 40mph then it is the loudest from there to 45mph. After that it quiets down and although still there is barely noticeable. I thought about tire or alternator noise but it definitely only does it during acceleration. Probably not much I can do now if it is trannie related. Thoughts?
Rutherford is offline   Reply With Quote
Old 04-01-2014, 11:30 AM   #2
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Considering that "lifetime" is officially defined 150,000 miles (most people get rid of cars soon after 100,000) you got your money worth from that factory ATF.
If I were you, I would drop the pan and replace the fluid and filter. I did that with the new-to-me yaris at 66,000 miles. Whether that fixes your tranny, remains to be seen.
Don't do a flush as flushed tend to kill neglected trannies.
jack black is offline   Reply With Quote
Old 04-01-2014, 12:20 PM   #3
Rutherford
Drives: 2008 Yaris
Thanks for the reply. I have been told that the filter is nothing more than a screen and some recommend just doing the fluid drain. Evidently there is a 10mm hex plug in the pan. The problem I have is I will be doing this on a gravel driveway and I may do more harm than good opening the pan under those conditions. Trannie is still shifting OK. Do you think the filter is really something I should absolutely do.
Old 04-01-2014, 01:57 PM   #4
jack black
jack black's Avatar
Not true:
Old 04-01-2014, 03:15 PM   #5
Rutherford
Drives: 2008 Yaris
I bet mine does not look that good. You just want to see an old man with gravel up his %%$ Well at least spring is trying to get here and I don't have to shovel snow to get-r-done
500,000 miles on my Yaris. trini_per4mance General Yaris / Vitz Discussion 133 04-10-2021 02:22 AM
Noise from rear of Yaris APS67 DIY / Maintenance / Service 5 09-25-2011 06:51 AM
