Old 04-03-2014, 01:12 AM   #1
MoneyT8
Drives: White Yaris Sedan
What that front cover/storage for?
Hello, my front cover just below the steering wheel doesn't close all the way and I was wondering if you guys knew the cause for it and a fix? Maybe replacing that cover. Just in case you guys didn't know what I was talking about I've have a link to the pictures.
http://i146.photobucket.com/albums/r.../CAM002601.jpg
Thanks in advance.
MoneyT8 is offline   Reply With Quote
Old 04-03-2014, 06:13 AM   #2
MyzticZ3r0
^error with the photo. You may want to check to see if a screw is missing - it shouldn't be ajar exposing the wires.
MyzticZ3r0 is offline   Reply With Quote
Old 04-03-2014, 09:47 AM   #3
sex
sex's Avatar
Drives: 09 5DR
Either something inside the basket is jamming it or the wires behind it are bunched up. Remove the basket and reinstall it
sex is offline   Reply With Quote
Old 04-03-2014, 10:00 AM   #4
MoneyT8
Ok I fixed the link; this has been driving me nuts for awhile. No there is no wire coming in or out of it. My guess is that the last owner abused the hell out of it. I don't even know what that basket or whatever it is for? Does anyone know the name of the part#? Thanks.
Old 04-03-2014, 09:50 PM   #5
Kar98
Drives: 2011 Scion tC
Wallet? Perfect size for one. Mine has an ID badge to let me into ...some building, a tire gauge, a pen, and a packet of tissues.
Old 04-04-2014, 08:00 PM   #6
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
I just use my side cubby as coin change holder for food drive-thru.
Killchain is offline   Reply With Quote
Old 04-04-2014, 09:26 PM   #7
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Great place for a wallet on long trips.
...and yes the stupid little metal clip comes off every once in a while.
Old 04-04-2014, 10:09 PM   #8
nookandcrannycar
I've used mine for lots of different things, including storing sunglasses. Currently, I use it to store paper clips.
Old 04-03-2014, 11:30 AM   #9
snapgarrett
Drives: 2007 yaris sedan
On the sides of it there are these little bulges that keep it shut, I put a bite of duct tape on them and it stays shut. It used to fall out all the time for me.
snapgarrett is offline   Reply With Quote
Old 04-03-2014, 12:26 PM   #10
There is actually supposed to be a small metal clip attached to top of the opening. They are easy to lose.
I though there was a separate part number for the clip, but I am not seeing one is the parts catalog.
Also check the bottom of the cubby. It is easy to bend the hinge part when snapping the cubby back on if they are bent then it sits higher than it should.
Tokico Reds, Blues, or Front swaybar for HS autoX? CoryM Tracking, Racing, Auto-X Forum 8 07-12-2013 07:35 PM
Front pad lifespan. o89canucks DIY / Maintenance / Service 47 08-20-2012 06:39 PM
*PICS* of my new lip kit: Seibon CF front lip, Kaminari side skirts and rear lip. PETERPOOP Photo-Video-Media Gallery 19 12-02-2009 11:45 PM
Aoe TigerTec..4k front, 3k rear....Tein Stech 3k front, 3.5k rear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 10-15-2009 11:44 AM
Front spoiler koolerking Australia 3 07-20-2009 09:10 PM
