Old 06-06-2014, 08:51 AM   #1
jasonk1123
Drives: Toyota Yaris 5 door hatch
Fan Blower Only Working On 4 FIX!!!
This will be a short DIY on how to replace your blown resistor on your Yaris, so that your fan works on all 4 speeds, not just 4!
Things you will need
1. Yaris
2. Philips screwdriver(a short one with a medium head)
3. 1* 87138 52030 (blower resistor part number) about $20 from Toyota
First locate your fan blower motor(mine was at the passenger side foot well)
Next move your attention toward the firewall or FRONT of the car. (The resistor sits about where you would imagine your right big toe would be if you were sitting in the seat)
You will see a black connector with 4 wires coming out the bottom of it(mines colours were black, green, white and blue) Push the connectors pin in and pull on the connector until it comes out(not the wires)
Locate the 2 screws that hold the resistor to the housing. Take a SHORT philips screwdriver(no you cant use a long one as there is not much space) Rotate the screws anti-clockwise(looking at them from the bottom) until they come out
Get your new blower resistor and insert it the same way the old one came out.
Reinsert the 2 screws(make sure that they are tight as the last thing you want is for the resistor to vibrate around and for the air from the blower system to escape from around the resistor, you will also see a sponge around the resistor for insulation)
Plug the connector back into place
And Bobs your uncle
There are no Yaris drivers, only Yaris LOVERS
jasonk1123 is offline   Reply With Quote
Old 06-06-2014, 05:55 PM   #2
jcboy
Drives: Sedan 07
does it look like this? :) sadly your images don't show.
Old 06-07-2014, 04:24 AM   #3
jasonk1123
Hi jcboy looks very similar.
If you right click on the image and click on the "open image in new tab" you should be able to see it:)
sorry man :)
Blower motor officially not working waydizzy DIY / Maintenance / Service 14 11-25-2023 04:41 AM
A/c & heater fan not working b_hickman11 DIY / Maintenance / Service 15 01-05-2016 03:09 PM
AC Blower Motor / Fan Does Not Turn on Period dyslexicanaboko DIY / Maintenance / Service 7 01-30-2012 10:59 PM
Blower fan question daf62757 General Yaris / Vitz Discussion 6 08-16-2011 06:27 PM
Why wont my fan blower work? lucy7509 DIY / Maintenance / Service 4 08-09-2011 02:48 AM
