Old 06-15-2014, 08:05 PM   #1
mpcv2000
mpcv2000's Avatar
Drives: 2004 Echo HB Hatchback 2 Door
Thumbs up Check what I found !
3 weeks ago my exhaust line snapped in half right after the resonator , I Gerry rigged it with some Canadian tire piping & "U" bolts.
Tail pipe had been fixed the same way by the previous owner so I'm in need of a full line.
I manage to find a brand new take off OEM silencer from a 2005 Echo Liftback .
but I'm still in need of the front part so while surfing my local KiJiJi I found this :
His pipe was also modified exactly where mine has been repaired by the previous owner so I'm still stuck but I asked the guy to cut it right after the resonator hoping I can manage to attached them together with more Canadian tire parts.
Here's my fix before finding the Borla .
Not pretty but it worked ( leaked as hell but ) .
The fix on mine by previous owner ( over the axle beam )
Now you guys can't laugh , this is my Sunday fix to be able to run the Borla.
To hold the back I think they just put some metal screws for the exhaust hanger in those 2 holes.
I did not like the idea so I drilled 2 big hole on the side to be able to insert 2 M8 nut to secure the bracket.
Here's some outside shots.
I really like it and it's not loud.
Car looks pink but it is the camera setting.
I just bought a EOS60D from Canon but I know $hit about camera.
I'll go somewhere to have it welded so I can remove all the "U" bolts I have put there.
mpcv2000 is offline   Reply With Quote
Found mirror shattered on the street. Four days later, rear ended by a Camry. nookandcrannycar DIY / Maintenance / Service 2 01-28-2014 07:51 PM
Check engine light on high revs jayeh DIY / Maintenance / Service 7 01-24-2014 09:26 PM
Paying for the Yaris with a check? YotaYarisUSA New YARIS Purchase Forum 15 07-11-2007 04:31 PM
