Old 01-22-2014, 07:33 PM   #1
jayeh
Drives: '08 Yaris LB
Check engine light on high revs
I found this previous post and was wondering if anyone has any more info since I had this happen to me today. http://www.yarisworld.com/forums/showthread.php?t=6133
I was about to merge on to a highway and put my shifter into 2 and floored it and it the car started to accelerate, then around 5k rpm dropped down about 500rpm, flashed the check engine light, I let off and reapplied the gas and it did it again. It happened about 4-5 times along the way too. It was cold out but the car was warmed up.
No codes were shown, no idea what is up. Seems fine on the way home.
any ideas?
jayeh is offline   Reply With Quote
Old 01-22-2014, 09:09 PM   #2
Misfires. Either you are due for plugs or you have a coil on the way out. If you have access to a code reader that can read historical as well as current codes you would be able to verify which cylinder the misfire was on.
Old 01-22-2014, 09:33 PM   #3
jayeh
There were no codes.
I've got a scan gauge connected.
It was the first thing I checked after I parked.
Old 01-22-2014, 09:40 PM   #4
ScanGauge only shows current not historical codes. You would need a more sophisticated reader for that.
Old 01-22-2014, 09:54 PM   #5
jayeh
What is a current code? It only shows me codes while they happen?
Whats the logic behind the gas cap being loose causing the CEL to stay on, but a misfire doesn't even make it stay on?
Old 01-22-2014, 09:56 PM   #6
Correct. A simple scanner will only show codes when the CEL is on. Smarter tools, like TechStream, show codes that occurred previously, but since have self cleared.
Old 01-23-2014, 11:58 AM   #7
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
Had this happen to me a few years back and in my case it was the spark plugs, you may want to check them.
Old 01-24-2014, 08:26 PM   #8
jayeh
New plugs are on order and they'll be here by the time I have a chance to change them!
Thanks guys.
Check Engine light and advance track light on 20104dr DIY / Maintenance / Service 2 10-31-2013 09:59 PM
Check Engine Light on at 32k kilometers? caper26 DIY / Maintenance / Service 21 10-16-2013 12:27 PM
Cold air intake....check engine light on...??? JohnnyMalice Performance Modifications 4 04-29-2012 09:46 PM
Check engine light Mr Yarisman Performance Modifications 7 10-24-2009 11:10 PM
