Misfires. Either you are due for plugs or you have a coil on the way out. If you have access to a code reader that can read historical as well as current codes you would be able to verify which cylinder the misfire was on.
| Check Engine light and advance track light on | 20104dr | DIY / Maintenance / Service | 2 | 10-31-2013 09:59 PM |
| Check Engine Light on at 32k kilometers? | caper26 | DIY / Maintenance / Service | 21 | 10-16-2013 12:27 PM |
| Cold air intake....check engine light on...??? | JohnnyMalice | Performance Modifications | 4 | 04-29-2012 09:46 PM |
| Check engine light | Mr Yarisman | Performance Modifications | 7 | 10-24-2009 11:10 PM |
