Old 04-15-2007, 07:13 PM   #1
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
adding power without any cost
i talk to a toyota tech here in qc and he told me we could had power .. here is how and i want to know if its true or b*llshit..
he told me to change the knock sensor of place and and fix it into a a/c compressor hole.. by changing it place, that exploits your advance of electronic fire..
so if someone heard about it..
OxyG3nE is offline   Reply With Quote
Old 04-15-2007, 11:41 PM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Sounds like BS to me. A knock sensor measures just that, knock, not engine timing. Adjusting timing can net gains on older engines, but, our engines have variable valve timing (VVTi). I don't believe it's adjustable. I'm not 100% sure, but I CAN tell you the knock sensor and A/C compressor hole (If that even exists???) have nothing to do with timing.
Old 04-15-2007, 11:46 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
since we have variable valve timing, it is always adjusting
Old 04-16-2007, 12:10 AM   #4
PetersRedYaris
That's exactly what I'm saying, it's not manually adjustable. It's all a function of the engine and computer.
Old 04-16-2007, 12:21 AM   #5
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
You guys are getting ignition timing and valve timing confused. VVT-i is VALVE timing.
The knock sensor is there to retard IGNITION timing if it senses knock. You don't want to be moving the sensor around. That is about the stupidest thing you could do.
Theoretically, yes the guy is right, but if there is no knock, then you will run the maximum ignition advance anyway, so moving the sensor is pointless.
If you do knock, the sensor sees it and pulls the ignition timing back to protect the motor. If you move the sensor, then you keep knocking, and start eating away at your pistions. But you gained 2 HP while you did it. Hooray for dumb.
Old 04-16-2007, 08:32 PM   #6
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Originally Posted by largeorangefont View Post
Hooray for dumb.
Hahahahahah... awesome quote!!!
2006 Red Blitzed RS 5-door
Old 04-16-2007, 12:18 AM   #7
only free performance mod I can thinnk of is to cut up holes in your stock intake filter box.
Although... the knock sensor's job is to change the timing to a "safe mode" if it feels the engine knocking. I guess putting it somewhere where it could not feel and knocking at all may run the ignition timing is a higher performance mode all of the time, but the risk of damage to your engine is pretty high if anything screws up!
Old 04-16-2007, 04:56 PM   #8
spkrman
Drives: 1
x2
Old 04-16-2007, 12:26 AM   #9
Black Yaris
der Zeck
When it comes to internals I am motarted
Old 04-16-2007, 08:16 PM   #10
ChinoCharles
Drives: LB
There is also removing interior goodies and running without the axleback.. I must try all of this one day. The best things in life are never free, are they my little turbocharger?
Old 04-16-2007, 08:39 PM   #11
OxyG3nE
i only ask :p
Old 04-23-2007, 04:13 PM   #12
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Don't trust these things.
Old 04-23-2007, 08:38 PM   #13
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
You know what they say about free lunches......
Old 04-24-2007, 10:24 AM   #14
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
Not sure if I would relocate it off the engine, but in my 2003 Sentra SE-R Spec V, the knock sensor relocate was one of the first things you always did. Primarily because the sensor was too sensitive. Relocation it further back on the engine kept it functional so you didn't nuke your engine, but it also kept it from pulling timing from something like intake noise. Just throwing in a bit of info from another car.
Ran Kizama is offline   Reply With Quote
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 02:59 AM
convenience vs. power package jeff_o General Yaris / Vitz Discussion 25 10-17-2006 10:04 AM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 11:51 AM
Custom Sub Enclosure (inc sub, power cap, amp) wado Items for Sale by private party 3 09-18-2006 11:53 AM
