![]() ![]() Drives: CS1 Join Date: Mar 2013
Rear hatch strut problem
Well this just happened, opened my rear hatch to put my work uniform inside, when I closed the hatch door I heard something popped inside.
I reopened it and noticed that were the strut connects to was loose(the black plastic piece was already loose when I got the car) now it looks like this...thought it was only the gas strut but now it looks like it has to welded back on? Anyone else run into this problem?? |
There is one other thread in here somewhere in which the exact same thing has happened.
oh ok ill look for it
I've been trying with all the obvious keywords I can think of with no luck. Pretty sure it was this forum, not MI.
#6 | |
soo pretty much i'll need new struts and get it re-welded at a shop... time to save up |
#7 | |
Best use of a Latin origin word to describe something award goes to this guy "left pneumatic arm's anchor"
Coincidence that the other occurrence was also a red hatch...
Since there are already holes.. I would drill the bracket and bolt it on.
![]() ![]() Drives: TOYOTA YARIS S 2009 Join Date: Dec 2013
Drill the bracket and bolt it on with rivnuts https://www.youtube.com/watch?v=P_uu_ba6qAM
| Does Toyota put loctite red on the rear strut bolts?? | DeathBeard | General Yaris / Vitz Discussion | 16 | 05-07-2012 02:27 PM |
| Sedan rear strut brace? | mrbond | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 05-21-2011 07:35 PM |
| Rear strut tower bar problem | mrbond | Performance Modifications | 25 | 09-22-2009 02:32 AM |
| Does anyone make a triangulated rear strut bar? | schleppy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-06-2009 10:56 AM |
