Old 07-31-2015, 10:05 PM   #1
SeanD
Drives: 2008 Yaris Base Manual Hatchba
Does anyone know of a Factory 4 Button FOB for 2008 3D Yaris
My daughter lost all the original keys with FOBs (keyless entry devices). I have purchased replacements from 2 different places. Everywhere I look shows 3 button remotes, even Toyota. She swears hers was 4 buttons (including back hatch release).
I have tried many times with 3 Button remotes from different vendors. I go through the programming steps just fine, I get the lock/unlock ack and then I try both lock and unlock followed by lock .... NOTHING.
If you have one, please send me any identification info you see on it.
It is a 2008 vin:jtdjt903285190280 <corrected>
Any ideas?
Thanks,
Sean
SeanD is offline   Reply With Quote
Old 08-01-2015, 08:00 AM   #2
nortonfb
Drives: 2007
Never saw a factory one.
The hatch lock being part of the door system would lock & unlock with the doors.
Mine is 4 button if you count the panic and aux button.
Sorry no help.
nortonfb is offline   Reply With Quote
Old 08-01-2015, 08:12 AM   #3
You have a digit wrong in your posted VIN.
There definitely was not an OEM power lock option with the hatch release. From the (correct) VIN I can tell if the car was built with OEM keyless entry, or if it actually had an aftermarket keyless entry system (which would make more sense with the 4 button remote)
Old 08-01-2015, 09:47 AM   #4
SeanD
Ooops Correct VIN
Sorry lysdexia! VIN: jtdjt903285190280
Old 08-01-2015, 09:49 AM   #5
SeanD
What does AUX do?
Sorry no help.
OK, but I think she was correct that the AUX button (not present on any I can find) opened the hatch. Her hatch release inside the car is electronic.
Got a part number, etc?
Old 08-01-2015, 09:50 AM   #6
SeanD
UPDATED Question.
I never tried the REPLACE programming, only ADD new remote. Could it be full and not accepting more?
Thanks,
Sean
Old 08-01-2015, 09:55 AM   #7
That definitely confirms non-OEM. No Yaris ever had a hatch release and definitely not an electronic one.
Now you need to poke around under the dash to find out what brand/model of keyless entry system is installed, so you can order a replacement remote for it.
Old 08-01-2015, 05:02 PM   #8
SeanD
OK, chalk that up to bad memory and confusing car models. No electronic hatch release - verified.
So, why won't it accept these new remotes? The fact that the key in, key out .. close and open ... routine goes into program mode and confirms with door lock/unlock seems to me to confirm Factory. We got it new from the dealer and it came with it.
Thanks for your response.
Old 08-01-2015, 09:22 PM   #9
Have you tried rewrite, instead of add mode?
Old 08-01-2015, 10:20 PM   #10
SeanD
Thanks again for your responses CT. I did get a chance to try REWRITE. I got to double lock/unlock confirmation and then it just does not seem to "hear" my remote.
I had a thought ... what fuse is the remote receiver on? That would explain my symptoms exactly. I don't think she has any blown fuses, I was just trying to figure out what would produce this situation. Of course dead receiver module is another choice.
Old 08-01-2015, 10:36 PM   #11
The door control receiver is on the DOME fuse. If that one was bad you wouldn't have a working radio or working dome lights, so I would not think that it is the issue. I is quite possible that something is wrong with the receiver.
With the Toyota Techstream diagnostics tool it would be possible to do significant troubleshooting.
Old 08-02-2015, 11:38 AM   #12
SeanD
OK, that is good news. I have ordered the laptop software and already have received the cable. I expect the software any day now. I may be asking advice on diagnostics very soon.
Thank you for your patients and for helping me track this down.
Sean
4 button, fob, keyless entry, keyless remote
Yaris Key fob wont lock my doors! Treeny DIY / Maintenance / Service 3 03-29-2012 07:27 AM
Yaris aftermarket push start button installed marschall DIY / Maintenance / Service 2 08-14-2011 05:48 PM
toyota yaris factory romram General Yaris / Vitz Discussion 15 07-14-2011 06:36 AM
