![]() Drives: 2008 Yaris Base Manual Hatchba Join Date: Mar 2014
Does anyone know of a Factory 4 Button FOB for 2008 3D Yaris
My daughter lost all the original keys with FOBs (keyless entry devices). I have purchased replacements from 2 different places. Everywhere I look shows 3 button remotes, even Toyota. She swears hers was 4 buttons (including back hatch release).
I have tried many times with 3 Button remotes from different vendors. I go through the programming steps just fine, I get the lock/unlock ack and then I try both lock and unlock followed by lock .... NOTHING. If you have one, please send me any identification info you see on it. It is a 2008 vin:jtdjt903285190280 <corrected> Any ideas? Thanks, Sean Last edited by SeanD; 08-01-2015 at 09:53 AM. |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Never saw a factory one.
The hatch lock being part of the door system would lock & unlock with the doors. Mine is 4 button if you count the panic and aux button. Sorry no help. |
You have a digit wrong in your posted VIN.
There definitely was not an OEM power lock option with the hatch release. From the (correct) VIN I can tell if the car was built with OEM keyless entry, or if it actually had an aftermarket keyless entry system (which would make more sense with the 4 button remote)
#4 | |
Ooops Correct VIN
#5 | |
What does AUX do?
Got a part number, etc? |
UPDATED Question.
I never tried the REPLACE programming, only ADD new remote. Could it be full and not accepting more?
Thanks, Sean |
#7 | |
Now you need to poke around under the dash to find out what brand/model of keyless entry system is installed, so you can order a replacement remote for it.
#8 | |
So, why won't it accept these new remotes? The fact that the key in, key out .. close and open ... routine goes into program mode and confirms with door lock/unlock seems to me to confirm Factory. We got it new from the dealer and it came with it. Thanks for your response. |
#9 | |
Thanks again for your responses CT. I did get a chance to try REWRITE. I got to double lock/unlock confirmation and then it just does not seem to "hear" my remote.
I had a thought ... what fuse is the remote receiver on? That would explain my symptoms exactly. I don't think she has any blown fuses, I was just trying to figure out what would produce this situation. Of course dead receiver module is another choice. |
#11 | |
With the Toyota Techstream diagnostics tool it would be possible to do significant troubleshooting.
#12 | |
Thank you for your patients and for helping me track this down. Sean |
| Tags |
| 4 button, fob, keyless entry, keyless remote |
| Yaris Key fob wont lock my doors! | Treeny | DIY / Maintenance / Service | 3 | 03-29-2012 07:27 AM |
| Yaris aftermarket push start button installed | marschall | DIY / Maintenance / Service | 2 | 08-14-2011 05:48 PM |
| toyota yaris factory | romram | General Yaris / Vitz Discussion | 15 | 07-14-2011 06:36 AM |
