![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
Hi all,
its getting summer now, so the cold AC is going to be in use. When the AC is running for quite a while, a bad smells starts to form. From reading around, its due to some crud in the water tray that gets wet. Is there an easy way to clean this that does not involve having to remove the entire dashboard to access that tray? I would like to clean it out but dont want to have to spend $400 to get it opened up. |
You can flush it with a mild bleach solution by pulling the hose out of where it goes through the floor (on the inside front of the front passenger foot well). Cover the carpet with plastic and use a turkey baster to squirt the solution into the hose, and then let it drain back out into a pan. Do that until no more crud comes out.
Thanks . Just bought a turkey baster. Will try it out tomorrow.
I did this. still have the smell. Do you think something like CarPlan odour stopper will work ?
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
Have to check to see if you have a cabin air filter? It's been known for my car (2007 hatch) to be lacking the cabin air filter so all the debris will be lodged there. If there is one, have you changed it?
#6 | |
After snooping around a bit, sounds like I am going to have to take that AC drip tray apart and give it a good cleaning. Also even the evaporator. I read that under a recall they changed the evaporator because mold grows on it. Wonder if I ring the dealer here and see if they will cover it ?
#8 | |
| Weird acidic smell from vent | darkmoon87 | General Yaris / Vitz Discussion | 4 | 09-01-2009 07:16 PM |
| Bad Driving Techniques | Altitude | General Yaris / Vitz Discussion | 10 | 02-10-2009 05:26 PM |
| Weird smell | Midon | DIY / Maintenance / Service | 4 | 01-26-2009 08:22 PM |
| Burning Smell | Treyz | General Yaris / Vitz Discussion | 21 | 11-24-2008 06:16 PM |
| Funky smell, should I take it to the shop? | death is my gift | DIY / Maintenance / Service | 6 | 08-12-2007 10:27 PM |
