Old 09-01-2009, 04:47 PM   #1
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
Weird acidic smell from vent
OK. I changed my cabin air filter 2 months ago so it is not that. I even took it out and visually checked it, too. It's not the smell coming from the cabin filter.
It is a very nasty and strong sweat + pee like scent that flows in whenever I turn my vent on. Smell is the same regardless of A/C being on or off (smells a little less bad when AC is on though) and regardless of re-circulation or regular airflow mode.
I have a short ram intake and I took a visual check on the outside of the intake filter and there's nothing. Now I am afraid if there's something dead somewhere inside my engine bay that causes this nasty smell..?
Any insight will be appreciated
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 09-01-2009, 05:08 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
There's quite a few threads on the stinky vent system. It's probably the same issue.
Old 09-01-2009, 05:27 PM   #3
supmet
Drives: 2007 4 Door Yaris
The stinky vent is a mold smell.
Coolant is the only "sweet/pee-like" smell I can think of. Check your coolant level, and all the lines coming out of the radiator for cracks or leaks.
Also, your intake goes in the engine and then out the exhaust. The A/C gets its air from the vents outside the windshield(or just inside for recirculate)
Old 09-01-2009, 07:12 PM   #4
Altitude
Altitude's Avatar
He mentioned sweat as in body odor or maybe he just misspelled sweet...
Old 09-01-2009, 07:16 PM   #5
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
Look at TSB 0103-09 for HVAC odors-you will probably find this to be your problem. The evaporator is not draining properly for the ventilation system-leading to a bad smell. Parts are on order for mine
Coolant Smell after sitting in hot sun? Snappy General Yaris / Vitz Discussion 3 05-31-2009 12:18 AM
Weird smell Midon DIY / Maintenance / Service 4 01-26-2009 08:22 PM
FS: NIB AutoventShade In-Channel Vent Visors + Like NIB TYC Tail Lights. IsLNdbOi Items for Sale by private party 14 12-11-2008 02:27 PM
Funky smell, should I take it to the shop? death is my gift DIY / Maintenance / Service 6 08-12-2007 10:27 PM
weird plastic melting smell nqd General Yaris / Vitz Discussion 27 08-10-2007 02:59 PM
