Old 05-11-2016, 10:43 PM   #1
alanwagen
The front pad DIY missing
Hey folks, I fixing to replace my son's front brake pads. I have done it many times before but not on a Yaris. Any surprises like left hand threads, etc?
I bought some OE Napa pads with new clips.
Do I lube the end of the pad within the clips? Also, on youtube they had the allenhead type or 14mm bolts. He has the American import so I hope it is the 14 mm, right? Any other tips. lay it on me bro.
Thanks and best regards, Alan
Old 05-12-2016, 10:33 AM   #2
Nothing is really different or unique about the Yaris front brakes over others you have worked on. Just do what you always did. And yes, there are no allen bolts on our assembly.
Old 05-12-2016, 12:19 PM   #3
bronsin
bronsin's Avatar
Don't forget to PUMP THE PEDAL UP before test drive!
Old 05-12-2016, 06:37 PM   #4
alanwagen
Thanks
Old 05-21-2016, 05:53 PM   #5
alanwagen
I did them today and it went quite well. Of course I lubed the caliper pins and they were in good shape anyway. Only small bit of rust on one pin which I knocked off easily. 14 mm socket and a 17mm wrench to hold the caliper pins. The Napa shoes came with shims and bracket hardware. 122,000 miles and yet there was still pad on the original brakes.
DIY: 60/40 Split Seat Install (some welding required) CTScott DIY / Maintenance / Service 13 03-05-2017 05:12 PM
MI SSK In-Cabin DIY (Golddeenoh) BEEF DIY / Maintenance / Service 5 03-26-2013 02:19 PM
Front Licence Plate kimona Cosmetic Modifications (Exterior/Interior) 23 09-24-2010 08:20 PM
Question about bi amping front components. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 08-28-2010 01:04 PM
Front brake pad replace: calipers piston dslc DIY / Maintenance / Service 3 07-17-2010 03:46 PM
