![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
YARIS Clutch Cable
All,
Can anyone advise how to replace the clutch cable or how can I lube it. I am feeling the clutch pedal is hard to press sometime. Clutch it self is working fine. thanks\ |
Good luck with that one, the clutch is hydraulic.
Cheers for that
Get someone to help you bleed the system. There might be some moisture in the line
Do i need to bleed it and then refill ?
It shares the system with the brakes. So just keep an eye on the level and make sure you don't let it go dry.
Is it this one to bleed
Yes. We motorcycle riders bleed our brakes and clutch once a year and change the fluid every two years.
Its cheap and easy, ensures proper operation, prevents untimely problems, keeps the bleeder bolts from seizing and snapping off when eventually you have to loosen them to bleed/change the fluid, and makes things last longer.
Is this the reservoir i need to refill. I havent done this before so any advise would be highly appreciated
Cheers |
which oil for refill
#14 |
DOT3 or DOT4 Brake fluid only. It says right on the cap and in your owner's manual.
#15 |
Cheers gents got it it is dot 4
#16 |
Thanks Gents it is much better now
#17 |
Did any nasty dark fluid come out
#18 |
Yeh thats strange bcz the one in container is clean not sure how all that gets in.
| How to tighten handbrake cable? (Yaris Sedan) | NadPhone | DIY / Maintenance / Service | 5 | 01-04-2018 10:55 AM |
| Aftermarket Clutch Q's | tmontague | Performance Modifications | 5 | 03-05-2016 04:33 PM |
| '54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem | Lettuce | UK | 0 | 09-30-2010 06:21 AM |
| Is it me or does the Yaris have a touchy clutch? | tomato | General Yaris / Vitz Discussion | 17 | 02-23-2009 08:33 PM |
