Old 10-06-2016, 08:32 PM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Hatch strut mount snapped
So today while closing my hatch heard a clunk and well end result, left side strut mount on the hatch side nearly pried off.
Things to note:
upgraded the struts to 120lb
lots of sound deadening mass vinyl so the upgraded struts was a must
probably slammed the hatch a few good times cramming things in
had the stronger struts for 3 years?
Fixed with Strap Toggles
Check out my Build thread:
Old 10-07-2016, 02:35 AM   #2
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
I don't think slamming the trunk would inflict that much damage to the mounts. Looks more like there was additional stress when opening the hatch beyond the stock height. Were the upgraded struts the exact same length as OEM? Could be possible that 120lb struts opened the trunk much wider than the OEM ones did.
07liftback is offline   Reply With Quote
Old 10-07-2016, 02:28 PM   #3
Not the first.
http://www.yarisworld.com/forums/sho...light=liftgate
http://www.yarisworld.com/forums/sho...ht=hatch+strut
Old 10-10-2016, 01:32 AM   #4
ezhacker1
ezhacker1's Avatar
I fixed it that same night. Crazy idea that actually worked....
Drilled the hatch side where the mount goes big enough to put a toggler snap toggle in, and also drilled the mount itself. So now the mount is anchored to the hatch as if it were a TV or wall fixture. Cost me just the togglers I had on hand or about 4 bucks.
I think the mount has the most pressure on it while closing the hatch as the strut is pushing against the weld. Its the same length strut so I don't think its over extending.... That's more of the hatch mount to the car frame issue. If theframe cracks where the bolts are that would suck.
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
gap at upper strut mount? 428CobraJet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 09-23-2015 06:53 AM
Rear hatch strut problem MiSFiTx87 DIY / Maintenance / Service 10 08-29-2014 11:15 AM
Strut mount (bearing) cause camber to be off? chaditotx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 07-02-2013 02:19 AM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
