Old 05-07-2015, 07:08 PM   #1
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
gap at upper strut mount?
I'm just buttoning up strut replacement. KYBs. I have a gap below the upper strut mount (engine bay). Normal? I knew this was the case beforehand...figured it was indicative of worn struts (among other symptoms)
Gap is about 3/8" on both sides when fully tightened (holding 6mm hex).
You are what you drive.
428CobraJet is offline   Reply With Quote
Old 05-07-2015, 07:35 PM   #2
LTHatch
Drives: 2013 Yaris Hatchback L
Do you have lowering springs? I noticed that gap after installing lowering springs, ride is fine and dandy as usual. Normal is my vote.
LTHatch is offline   Reply With Quote
Old 05-07-2015, 07:43 PM   #3
428CobraJet
No...standard springs. 130,000 miles.
Old 05-07-2015, 08:11 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Normal on a yaris
Old 05-07-2015, 08:17 PM   #5
428CobraJet
Well...what keeps the upper suspension location from moving around?
Old 05-07-2015, 08:20 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
They are floating top caps ...park car on uneven ground and ull see how they work ....and yes they float its why upper strat bar is pointless on a yaris.
Old 05-07-2015, 08:21 PM   #7
428CobraJet
Interesting. Thank you. I hope my struts were in fact bad...
Old 05-07-2015, 08:22 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
The strut is held by 2 nuts and a cup that u see in ur pic ...upper nut keeps it in place the lower one under keeps the spring in place.
Old 05-10-2015, 03:00 PM   #9
sheekeebut
Minimalist
Drives: 07 silver sedan
Lots of threads about it here.
It's called floating strut mount.
Main point of it is to allow the struts to rotate freely at various steering angles while accounting for caster, camber, etc. Similar in purpose to a ball joint. You'll notice this effect by turning full lock, pop the hood to see. The hats tilt a little relative to the towers.
Other cars have it, not surprisingly in the same segment.
sheekeebut is offline   Reply With Quote
Old 05-10-2015, 03:04 PM   #10
sheekeebut
Minimalist
And exiwolman's not totally right about the strut brace being pointless. My strut bar has just added 20 style points and a kilo of weight to my engine bay. That should be worth some extra hp, right?
Old 05-10-2015, 03:11 PM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
LMAO....agreed at least 10 points for appearance
Old 05-10-2015, 03:23 PM   #12
428CobraJet
Btw Chris07LB article on changing the strut really saved the day.
Old 09-22-2015, 11:49 PM   #13
SirDigby
Drives: 2007 yaris 3 door
the brace still helps against tower collapse over time. as a vehicle ages the towers will change shape/geometry due to gravity and use. a strut brace helps to counter-act this effect and keeps the geometry more correct for the longevity of the vehicle.
Old 09-23-2015, 06:53 AM   #14
Rigaud
Drives: 2009 Yaris
Strut tower bars don't mount on the cups or strut itself in general but on the strut tower which technically is the car frame!
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Strut mount (bearing) cause camber to be off? chaditotx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 07-02-2013 02:19 AM
Nitto Upper front Strut bar San Diego solarVitz Items for Sale by private party 8 03-14-2012 01:14 PM
Looking for Upper Shock/Strut Mount?? tobymak21 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-08-2009 01:47 PM
Nst short shifter, short antenna, and upper strut bar dacourier Items for Sale by private party 6 07-08-2009 09:52 PM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
