Old 02-18-2011, 12:17 PM   #1
jemmah
Drives: Toyota Yaris
VALVE ADJUSTMENT INTERVAL
I have a 2007 Yaris hatch with 138000 miles. This Yaris has been great other than half-a-dozen headlights each year. I try to do all my own maintenance.
Compression is good all cylinders but it's such a project to check valve lash that the Toyota manual states that valve clearence is checked by a Toyota technician with a stythiscope. I assume having Toyota preform this task would cost me a bundle plus they probably would adjust them whether they needed it or not and there goes the $$$$. I few Yaris owners I spoke to say they never needed a valve adjustment BUT my mileage is higher than most.
I want to know from someone who really knows: What is the point in time where most Yaris's require a valve adjustment. Not a single person I've talked to needed one BUT as we all known this auto had solid lifters and a adjustment should be needed sooner or later. They must be using some serious metal for this area of the engine!!!!
Thanks,
JEM
jemmah is offline   Reply With Quote
Variable Valve Sensor Error Craig DIY / Maintenance / Service 13 06-22-2013 03:29 AM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Valve train Noise hatchbackkid82 DIY / Maintenance / Service 6 12-28-2010 02:27 PM
Ferrea valve upgrade kit cali yaris Micro Image 4 07-28-2010 11:52 AM
Adjustment to the upper shock mounting point? Goose Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-07-2010 03:41 PM
