Old 10-19-2006, 04:15 PM   #1
barryware
Valve Noise
I have had my Yaris for about 6 weeks. I just noticed that after the engine is warmed up, there is a "ticking" noise from the engine. It is typical of when an engine is in need a valve adjustment. However, a new engine shouldn't need a valve adjustment. In doing a little research, these are not the typical type of valves to adjust. You have to measure your clearance, do a little math, and replace the lifters with ones of differant size.. Boy!!.
So... Am I being to critical of the engine / valve train noise? When the engine is started and cold, it is a quiet as can be. Once warmed up, the valves are ticking.
I have owned several 4 cylinder powered cars and none have ticked.
Someone said that it may be the fuel injectors I am hearing. This would not explain why when the engine is cold that the sound is not there.
I guess I should bring it in but warranty or not, taking in a car is a pain in the a$$.
Anyone else have a ticking engine?
barryware is offline   Reply With Quote
Old 10-19-2006, 09:43 PM   #2
I noticed a similar kind of sound on mine after driving for a while and opening the hood. Then we checked a friend's Corolla and it had a similar kind of sound.
I'm not sure if it's the same in your case but the sound did seem to come from the belt, not the engine itself.
I may ask the technician about it at the next service, but it does not seem like anything serious, maybe just part of the engine breaking in.
Old 10-19-2006, 09:50 PM   #3
Lafiro
Drives: 06 Yaris Sedan
Same annoying sound here too.
Old 10-20-2006, 12:05 AM   #4
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
It's normal to have some slight valve tick
It's better to have a little noise/tick then no noise/tick. No valve noise means the tolerances are too small.
Heavy ticking means the tolerances are too big.
When the engine is cold the oil is heavy and excessive roping is common until oil temps reach normal operatin temps, also the engine tolerances change as the engine heats up.
Do yourself a favor and start usinga good synthetic oil like Amsoil or Redline then you won't have to worry about valve adjustments for a VERY VERY long time.
Old 10-20-2006, 08:16 AM   #5
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Same sound here.
I have it between the 1500-3000rpm.
Then it goes off.
Old 10-20-2006, 10:47 AM   #6
barryware
Thanks everyone..
I guess I feel better..
Old 10-25-2006, 12:46 AM   #7
machine1
machine1's Avatar
Drives: 07 Yaris Liftback
Send a message via AIM to machine1
My 01 Tacoma ticks really loud at idle, ever since I bought it with 13K miles on it. Upon closer inspection, it was the injectors.
As long as the ticking doesn't increase as the engine speed increases, it's not an issue.
machine1 is offline   Reply With Quote
Old 10-26-2006, 12:02 PM   #8
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
Send a message via MSN to Teruyume
It's normal on these 1nz engine.... it's on all of them no matter how new or old they all have it..... never driven one doesn't have the noise >_<
06 Yaris RS 2Dr HB 5MT Orange
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Kumho Ecsta AST 195/50R15
Tanabe DF210
JDM LED Tail lights
Teruyume is offline   Reply With Quote
Old 12-11-2006, 01:08 PM   #9
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Especially a new engine might be in need of valve adjustment. The noise you hear doesn't necessarily mean a valve with too much gap. However, too tighten valves don't make any noise and it's even more damaging. A gap check at the first oil change would be a good idea.
hystria is offline   Reply With Quote
Old 12-18-2006, 03:34 PM   #10
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
It's a Toyota thing. I have had several Toyota 4 cylinders and they all seem to "tick". My 99' Tacoma 2.7L ticked loudly from the time I got with 30,000 miles untill I sold it with 117,000. It never caused a problem or got any worse, just always did it. Toyota's 22R also is notorious for loud ticking. Now my new Yaris ticks. I'm sure your car is fine.
Old 12-19-2006, 03:42 AM   #11
Katana
Katana's Avatar
Same opinion here.
Old 12-19-2006, 09:34 AM   #12
nsmitchell
nsmitchell's Avatar
Yep, a little ticking means the engine is running normally.
Get YarAss in gear!
RIP - Casey Tatum
Old 02-07-2007, 11:14 PM   #13
Scooterman
Drives: Vespa GT200L
Same noise here. Sounds like a little diesel when it's hot and idling.
I won't worry until a rod comes through the hood. :)
Scooterman is offline   Reply With Quote
Old 02-09-2007, 07:20 AM   #14
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
my corolla did it and my yaris does it. normal.
tekmoe is offline   Reply With Quote
Old 02-09-2007, 10:44 PM   #15
spkrman
Drives: 1
my 93 (or 95???) altima ticked...
then one fateful day doing 125 on the highway... it threw a rod right through the radiator. Was a very fun car to drive, i'd say even more so than the yaris
that post was entirely on topic, btw.
Old 02-10-2007, 07:01 AM   #16
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Thought it was just the injectors? Or maybe time is running out, and the last tick will be my last..
Old 02-10-2007, 07:23 AM   #17
spkrman
Drives: 1
tick tick tick tick tick....
"So much for the yaris being a green car"
Old 02-10-2007, 11:20 AM   #18
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
I've got a conspiracy theory. IT'S THE NORMAL SOUND OF THE MOTOR, NOT VALVE TICKING!!!
Nimble is offline   Reply With Quote
noise while backing up jonr0613 General Yaris / Vitz Discussion 31 09-08-2007 06:23 AM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
Loud scratching noise dngz General Yaris / Vitz Discussion 3 09-11-2006 10:56 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 06:14 AM
