Drives: Yaris Join Date: Jun 2017
Fog light problem
Hi, I wired in a set of fog lights. I bought the headlight stalk with the fog. And the blue relay. I got everything wired in. And the fog lights didn't come on. I tried turning the high beams on and off just to make sure I wasn't on the wrong one. I took the blue relay out and jumped it and the fog lights did turn on. So the wiring in the engine bay is correct. The only thought I am having right now is the running light relay is disconnected. I can't find it or I would have tried it. If anyone has fog lights could you help me out and disconnect the running light relay module. And see if your fog lights turn on thanks
| Fog Light wiring | Rammy | DIY / Maintenance / Service | 0 | 11-08-2012 08:34 PM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 06:37 PM |
| Sorry! Another fog light question. | Jrilla | DIY / Maintenance / Service | 4 | 08-23-2009 02:25 PM |
| My Yaris Fog Light | ezlove0710 | DIY / Maintenance / Service | 7 | 08-07-2009 06:15 PM |
| Fog Light Misalignment and Moisture | DjT | General Yaris / Vitz Discussion | 3 | 04-27-2009 03:24 PM |
