Old 08-06-2009, 09:38 PM   #1
ezlove0710
Drives: Black Sand Pearl
My Yaris Fog Light
I have a toyota yaris sedan.
and i bought the aftermarket fog light from ebay.
and it is not clear, not yellow, but smoked.
and i also bought Putco's H11 light bulb.
I installed it a month ago.
at first, it was pretty cool, you can see the light directly through the glass.
but after a few days, it became very "foggy". The light didn't go through the glass anymore, well, you can see the light but not clearly as headlight.
does anyone know what's the problem?
was it because the light bulb was too hot ? (6000k)
or was it because the Smoked housing I got that temperature was too hot to burn my housing?
ezlove0710 is offline   Reply With Quote
Old 08-06-2009, 09:55 PM   #2
1NZYaris1
1NZYaris1's Avatar
Sounds like the Smoke film is on the inside of the lens , and you cooked and
burned the film from the heat of the lights , my guess for what it is worth .
Put up some pic's
Old 08-06-2009, 09:55 PM   #3
Remove the bulb and see if the fogginess is moisture. Some of the aftermarket fogs don't seal well. The Putco H11's are 55W, which is the correct wattage. The color temperature doesn't mean that the bulbs run hotter, it's just a measurement of color output.
Old 08-07-2009, 04:21 AM   #4
ezlove0710
I checked my fog light a few hours ago, and i think the film is on the inside of the lens...that sucks....
but i'm afraid if i purchase a new clear lens fog light... it's gonna burn and become foggy again.
Old 08-07-2009, 06:35 AM   #5
1NZYaris1
1NZYaris1's Avatar
As long as you get , clear lens lights and they come standard with h11
bulbs you , should be fine
Old 08-07-2009, 05:31 PM   #6
ezlove0710
Can i use the "putco" H11 light bulb instead?
will it burn the lens again.
I havent get the fog light off to check it out what exactly happen inside of the lens, but i hope it's not the plastic got burned.
Old 08-07-2009, 06:11 PM   #7
1NZYaris1
1NZYaris1's Avatar
What Wattage are they , if they are above 55watt's you will diffenitly need the
Clear len's
first of you need to pull one of your foglights off to determin what the problem is
Old 08-07-2009, 06:15 PM   #8
ezlove0710
yeah it's 55w. I will definetly check it out once i have time..
Thank you so much for answering my question.
DIY Fog Light Parts . 1NZYaris1 DIY / Maintenance / Service 31 09-14-2009 01:44 PM
WTB: Driver's Side Fog Light MadMax Willing to Buy by private party 0 11-29-2008 12:58 PM
