Old 03-20-2009, 03:01 AM   #1
1NZYaris1
1NZYaris1's Avatar
DIY Fog Light Parts .
When you purchase any after market YARIS fog lights ,ie Sedan or Hatch Back
You should also purchuse or make the following parts
These will allow you to PLUG into the factory wiring (no running wires through firewall) (must have)
PURCHASE FROM Micro Image - cali yaris
The relay goes under the dash as per diagram , (must have)
If you want to use the aftermarket switch supplied you must remove it from the wiring loom supplied
so it looks like the photo, then wire it in as per other diy's (or you can PM me and i wil send you the factory instructions)
Or you can go and buy the factory light stalk and do no wireing in the cabin. just plug it in . (optional )
Old 03-20-2009, 03:58 AM   #2
RogueYaris
Drives: 2015 Abs Red
Thanks for this info, I've been thinking of getting some fogs.
RogueYaris is offline   Reply With Quote
Old 03-20-2009, 04:43 AM   #3
1NZYaris1
1NZYaris1's Avatar
The above parts are a must have
Old 03-20-2009, 09:46 PM   #4
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Im waiting on this kit to get here
Does that harness look like what your sayin?
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 03-20-2009, 09:59 PM   #5
1NZYaris1
1NZYaris1's Avatar
The harness in these Kits need to be modified if you want to plug into
the factory wiring, thats why you need to make & or buy the above parts .
Otherwise you can use the kit wiring but you will need to find a way to run the wiring into the cabin.
The Choice is yours
Old 03-20-2009, 10:10 PM   #6
Arkhangel
Arkhangel's Avatar
Got it
Old 03-20-2009, 10:14 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
I see so with this mod the fog lights will come on when you turn on your lights and no need for a special switch?
Old 03-20-2009, 10:32 PM   #8
1NZYaris1
1NZYaris1's Avatar
You need to use eathier the switch in the kit or buy the light stalk with built in switch from toyota .
the end result by useing factory wiring is the dash symbol for fogs also turns on , and sounds light alarm if they are left on with car turned off .
Old 03-20-2009, 10:44 PM   #9
YarisSedan
Ahh i see what you mean. I didnt even know there was a dash symbol for fogs lol.
Old 03-21-2009, 07:27 PM   #10
Arkhangel
Arkhangel's Avatar
im bit dense right now lol
what cable is that Labeled C
Is there a better datailed how to??
Old 03-21-2009, 10:17 PM   #11
1NZYaris1
1NZYaris1's Avatar
C is the negative (earth ) factory diagram shows it connecting to the battery.
Old 03-21-2009, 10:26 PM   #12
Arkhangel
Arkhangel's Avatar
Still dont get it, ok i got the kit today and well wanted to connect it "Factory"
how can i hack / splice / wire the harness that came with the kit to achieve this?
Old 03-22-2009, 12:00 AM   #13
1NZYaris1
1NZYaris1's Avatar
PM'ed , but as above you need to purchase or make the above parts in photo's .
if you look at your photo of what you bought the loom on the left goes
under to bonnet and connects to the lights , then make or purchase
the red wires in my first photo . that is what connect you into the factory wiring.
inside the cabin
take the wiring loom on the right in your photo , take the plug that connects to the on/off switch follow the wires back as far as you can
and cut them of the loom (as per photo 3 in my first post)
now depending on how you want your lights to work , will depend on where you put those wires
Old 03-22-2009, 09:26 AM   #14
Arkhangel
Arkhangel's Avatar
ok understanding a bit more. lol i was like
Old 03-22-2009, 11:09 AM   #15
yeah, I'm still like that and I sell the kit.
Old 03-22-2009, 11:50 AM   #16
Arkhangel
Arkhangel's Avatar
whats needed for the factory install, im installing it loosely for now just to have it on, but if i can install it where when i turn the fogs on the indicator on the dash turns on that would be sweet
Old 03-22-2009, 06:02 PM   #17
1NZYaris1
1NZYaris1's Avatar
You 2 are shocker's , or is my spelling and english that bad .
oh well you could always pay my airfare over , and i could teach you .
better still you could come too New Zealand , for your a Holiday , and
bring me a bonnet and front bumper and i will teach you .
Old 03-22-2009, 06:48 PM   #18
Arkhangel
Arkhangel's Avatar
Whos is the Offer directed to lol
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY - fog light install kurokoma-kun DIY / Maintenance / Service 3 09-18-2012 12:52 AM
Rav4 and Highlander fog light parts 1NZYaris1 Items for Sale by private party 5 02-13-2009 10:43 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
