Old 12-11-2017, 04:05 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Oil Pan Drop
Dropped the pan today to check the condition of the oil pickup tube screen.
I think that the multiple short oil changes I did really helped to clean things up. Much of the varnish that was in the pan wiped away with a shop towel. I think the detergents in the oil are slowly loosening things up. The pick up screen, much like the oil control valve was very clean.
I put a new filter on and filled up with 1L of Pennzoil Ultra 0W40 and the remainder with SuperTech 5W20 synthetic. This will be my last short oil change before I resume normal oil change intervals with my stash of Quaker State 5W30 conventional.
Valve cover comes off next week and valve clearances checked.
Pan off...
Pick Up Tube Screen...
Pan...
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Checking oil in the Yaris jb48 General Yaris / Vitz Discussion 16 09-15-2015 04:15 PM
Oil Return on upper oil pan sub assembly BoostedTRD Forced Induction Forum 6 11-10-2014 10:23 PM
FS: ZAGE oil Pan TURBO YARIS Items for Sale by private party 1 03-07-2014 01:00 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
