Old 12-12-2017, 09:44 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Unless you're willing to pull the cams and change buckets, there's no point in checking the valve clearances. And unless it's leaking I would leave well enough alone. If you pull the cover make sure you have a new gasket to put it back on, or it will leak after that.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Checking oil in the Yaris jb48 General Yaris / Vitz Discussion 16 09-15-2015 04:15 PM
Oil Return on upper oil pan sub assembly BoostedTRD Forced Induction Forum 6 11-10-2014 10:23 PM
FS: ZAGE oil Pan TURBO YARIS Items for Sale by private party 1 03-07-2014 01:00 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
