Back up lights don’t work
i’m working on a 96 tersel Who’s the back up lights don’t work. The owner says the balls were changed a couple years ago and I haven’t checked them yet but I’m assuming they’re good. Where would the switch be that actuates the back up lights? i’m assuming it must be either on the transmission or the shift lever of the automatic transmission but any heads up would be good, especially if you know about Tercel’s! Thanks!
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback Join Date: Jul 2016
I would also check every single fuse on the car. Also, will the car start in other gears besides park or neutral?
-Karl the Uber/Lyft Driver |
I’ll check and get back to you. I have the car up on ramps and checked for a switch on the transmission or couldn’t find movies. It was on ramps it’s down now
Nope it only starts in p and n. To exhausted from changing the coolant and clean the battery terminals right now to check the fuses. I’m not sure I can get down on that level to see the ones under the dash I have Parkinson’s
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| back up lights...amber? | matthewai | Cosmetic Modifications (Exterior/Interior) | 23 | 04-05-2011 01:19 AM |
| Why would my tail lights work but not my brake lights? | rickyml | Middle East | 11 | 10-06-2010 10:27 AM |
