Old 10-04-2010, 01:38 AM   #1
rickyml
rickyml's Avatar
Drives: Yaris 2008
Why would my tail lights work but not my brake lights?
I just changed my spoiler third light last night and it was working properly. then suddenly, nung ipi-fix ko na sya to return to original place nawala na lahat ng brake lights ko. hindi kaya sa fuse? saan ba located ang fuse box nito?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 10-04-2010, 02:43 AM   #2
syntax
syntax's Avatar
insan, na check mo ito..
http://www.etimago.com/yaris/repairmanual/Lighting.pdf
Old 10-04-2010, 03:50 AM   #3
rickyml
rickyml's Avatar
Drives: Yaris 2008
ayos na insan... pambihira... putol nga ang fuse ko sa may ilalim ng dashboard... tapos pati spare ko putol din... hehehe.
Old 10-04-2010, 05:42 AM   #4
BlessedYaris
BlessedYaris's Avatar
Drives: Yaris Gray "Blessed"
Send a message via Yahoo to BlessedYaris
so maybe okey pa yong pinalitan mo?
God Bless !!!
BlessedYaris
0552829596
BlessedYaris is offline   Reply With Quote
Old 10-04-2010, 05:53 AM   #5
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
sa SACO, mura lang ung replacement fuse..putulan mo lang ng terminal via side cutter plier.
Or pag OEM via ALJ, 15 rials each..Ang masakit nung last na naputulan ako ng fuse eh inorder pa sa Jeddah which took me 3 days to wait..
ricepower is offline   Reply With Quote
Old 10-04-2010, 08:28 AM   #6
rickyml
rickyml's Avatar
Drives: Yaris 2008
ganon ba? titingin nga ako mmaya sa mga autoshops d2.
Old 10-04-2010, 02:08 PM   #7
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol baka nung binalik mo sa original place may nagdikit na wire na nag caused sa pagka busted ng fuse mo, check it again before replacing a new fuse otherwise magsasawa ka kakapalit ng fuse kasi puputok lagi yan, hehehe
duke_afterdeath is offline   Reply With Quote
Old 10-04-2010, 03:21 PM   #8
rickyml
rickyml's Avatar
Drives: Yaris 2008
@duke. oo nga napansin baliktad yung wiring na nilagay ko. neg to neg dapat... pero napagpalit ko sa neg to positive. ok na bro. thanks
Old 10-05-2010, 10:50 PM   #9
syntax
syntax's Avatar
insan buti ok na, dapat pala lagi tayo may spare fuse
Old 10-06-2010, 01:39 AM   #10
rickyml
rickyml's Avatar
Drives: Yaris 2008
@syntax... may 3 spare fuse tlaga dyan sa fuse box sa hood. 10 (red), 15 (blue), 20 (yellow).
Old 10-06-2010, 01:43 AM   #11
syntax
syntax's Avatar
tanong lang insan, pano naputol ung spare din?
Old 10-06-2010, 10:27 AM   #12
rickyml
rickyml's Avatar
Drives: Yaris 2008
ewan ko nga ba. 5SR lang naman yon 4pcs.
FS: JDM Replica Tail Lights kustom play Items for Sale by private party 29 01-20-2010 01:00 PM
DIY LED Tail (Rear) Head Lights dg4rez DIY / Maintenance / Service 11 12-21-2009 04:10 AM
07-08 tail lights same as 09? eocintron Cosmetic Modifications (Exterior/Interior) 5 11-24-2009 03:53 AM
Smoked tail lights: film, paint or replace? Herbicidal Cosmetic Modifications (Exterior/Interior) 30 10-19-2009 02:01 PM
Black Altizza tail lights.. w/ pics Jerkratt Cosmetic Modifications (Exterior/Interior) 44 06-10-2007 11:12 PM
