Old 11-15-2018, 05:32 PM   #1
douchenozzle
Drives: '07 Yaris
caliper bracket and caliper bolt sizes (07 yaris)
anybody know what the bolt sizes are for the bracket and the caliper ? thanks
douchenozzle is offline   Reply With Quote
Old 11-15-2018, 06:40 PM   #2
DarkShadowFox
take the bracket and bolt off and look at it ?
Old 11-15-2018, 06:45 PM   #3
ex-x-fire
Do you need the wrench/socket sizes? You can do a lot on a Toyota with 10,12,14,17,19, 21 mm stuff.
Old 11-15-2018, 10:20 PM   #4
douchenozzle
Drives: '07 Yaris
mainly looking for sockets for a breaker bar. have a feeling i'll need it thanks to rusty ol' northeast.
Old 11-15-2018, 07:56 PM   #5
12 and 17 I think. Why do you ask? Planning on going to tool store and buy individually what you need?
Sent from my EML-L09 using Tapatalk
Old 11-15-2018, 10:15 PM   #6
douchenozzle
Drives: '07 Yaris
yes. i only have access to the car on the weekends. It's my sister's car. thinking of buying the missing tools i need on friday so i can work on it saturday.
Old 11-15-2018, 07:57 PM   #7
tmontague
tmontague's Avatar
14 and 17mm
Old 11-15-2018, 10:15 PM   #8
douchenozzle
Drives: '07 Yaris
Originally Posted by tmontague View Post
14 and 17mm
thanks tmontague. much appreciated.
Old 11-16-2018, 06:43 AM   #9
tmontague
tmontague's Avatar
Np, have a 12mm with you just in case, Weeyari may be correct that the slider bolts are 12mm but I'm pretty sure I grab a 14 and 17mm when I swap my pads and rotors before I go the the track.
The caliper bracket bolts are on there tight so use a breaker bar, the slider bolts are not torqued too tight so you should be fine. Just make sure you use anti seize on the threads when you re install. These cars are easy to work on once you removed every bolt at least once and coated it in anti seize, other wise the salt takes a toll and makes basic jobs a headache
Old 11-16-2018, 01:03 AM   #10
komichal
Well my Yaris 2007 with 2SZFE uses 7 or 8 mm allen key to get the caliper off.
I would recommend to get some basic toolset, with nuts and allen keys. But as you do have a breaker bar then I guess this basic toolset is already in your inventory.
Old 11-16-2018, 09:24 AM   #11
I just checked on some spare slider bolts I have in the garage. They are indeed 14mm.
Probably more cost effective to buy a socket pack that ranges from 8mm to at least 19mm. That way you are good to go with pretty much everything the future may throw at you.
Old 11-16-2018, 11:50 AM   #12
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
French produced yaris with Ate calipers in front and rear has 7mm allen slider bolts.
Has just changed pads on the 13 today.
And got the winther tyres on 4 nice new continental TS860
Thankfully it has drums on the rear here in denmark with salty roads in the winther.
The rear discs on the hybrid is a PIA they must have service at least once a year or they will get complete grown together.
The hybrid also has 7mm allen slider pins both in front and rear.
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Passenger side caliper loose... baseballfan416 DIY / Maintenance / Service 5 08-17-2016 10:35 PM
Wtb front passenger brake caliper bracket with slider bolts.... baseballfan416 Willing to Buy by private party 7 07-29-2016 10:47 PM
looking for torque specs on front caliper bolts 07 yaris mikee07 DIY / Maintenance / Service 2 10-21-2012 03:36 PM
