#1 |
![]() ![]() ![]() Drives: 2017 L 3-door Join Date: Mar 2011
Wtb front passenger brake caliper bracket with slider bolts....
Replacing brakes this morning and one of the slider bolts on passenger side is essentially seized with the rubber boot almost completely shredded. Looking for a front passenger side brake caliper bracket (ideally with the bolts).
#3 |
thanks for the link
#4 |
Heat on the bracket where the slider pin is plus an impact gun to spin it out, after clean slider pin replace boot and clean the inside of the bracket pin area.
Sent from my ONEPLUS A3000 using Tapatalk |
#5 |
But if your in Toronto, Collingwood area I have a spare one....you can have.
#6 |
Good advice and OP is in Wisconsin.
#7 |
So the bolt moves but it only comes out part way... Are you guys saying I can technically reuse the bolt and bracket with a new rubber boot, assuming I can heat the bracket and actually get the bolt to come out?
#8 | |
Now sounds like ur slider pin is stuck and I bet it's the lower one, just try to spin it out since it's moving while pulling at same time with pliers. If completely stuck one needs to heat the bracket and than spin pin. To answer ur question... Definitely one can reuse just make sure it's nice and clean, a drill bit works perfectly as long as it's same size as pin to clean inside the bracket, as for pin just wire brush.. Lube all with new boot and good to go. Also the problem is do to no maintenance but mostly the stupid rubber insulator rubber ring at the end of the pin and I bet that is what is stuck, it's just for sound repression and really serves no other reason so don't use it. Sent from my ONEPLUS A3000 using Tapatalk Last edited by Exiwolfman; 07-29-2016 at 11:01 PM. |
| WTB: 07 Sedan Front Grille combo + passenger headlight | knockoutking | Willing to Buy by private party | 7 | 11-02-2009 10:26 PM |
| WTB - Passenger Side Seat Bracket | lunjiaow | Willing to Buy by private party | 3 | 09-08-2009 05:03 AM |
| WTB: 07/08 liftback front passenger fender liner | solarVitz | Willing to Buy by private party | 0 | 07-02-2009 07:22 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| Coilovers - creaking sound from passenger front? | Gideon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 03-16-2009 03:20 PM |
