Old 10-30-2019, 08:31 AM   #1
Cartel
Cartel's Avatar
Drives: 2007 Yaris Hatch is sold
Exclamation 2007 Yaris Charge voltage too low, tried everything
My alternator has been giving me trouble and has a low charge voltage.
I took it apart and cleaned the regulator, checked the brushes and cleaned up the commutator and it all looks good (60,000KM).
The problem is it only charges at 13.6v-13.8v with nothing on while another identical car charges at 14.2v-14.4v.
I checked for voltage drop at full load (130mv) positive and negative (0.001mv) and AC (0mv)
I think my audio amp may have hurt it somehow. (guessing)
I am looking for a heavy duty alternator if possible or I guess I'm going to replace the regulator and see if that helps.
Could the ECM be damaged somehow?
I can find my alternator (27060-21150):
But I also see one with a bigger heat-sink on the regulator and a bigger body too:
Is there a better version?
These both say 80 amps but 1 looks much beefier.
My audio amplifier only uses 40 amps.
Thanks
Cartel is offline   Reply With Quote
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
