![]() Drives: 2004 1.0 yaris Join Date: Feb 2023
Wheel studs
Hi
2004 1.0 yaris Can I replace front wheel studs without removing hub? Thanks. |
You should be able to, there should be a notch in the knuckle for the stud to pass through.
You'll have to take the caliper and rotor off. |
| Replace wheel studs on rear. | CB900F2 | DIY / Maintenance / Service | 1 | 06-20-2022 06:19 PM |
| ARP Wheel Studs | ArmstrongRacing | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 12-15-2018 11:08 PM |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| Longer wheel studs for 5mm spacer? | Captain Slow | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 02-09-2013 10:35 PM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
