Old 06-20-2022, 06:12 PM   #1
CB900F2
Drives: 08 Sedan
Replace wheel studs on rear.
Hey all..
I need to replace the wheel studs on my sons 2008 Sedan , is there enough room for when I removed the stud from the hub to get the them in and out?
Just wanna make sure this is the case before I buy the new wheel studs...
Thanks all!
CB900F2 is offline   Reply With Quote
Old 06-20-2022, 06:19 PM   #2
Yes, there is room. There is room for studs up to 10mm longer than OE.
Rear wheel hub assembly replacement David C DIY / Maintenance / Service 19 06-15-2020 07:08 PM
Need longer wheel studs Decieved Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 02-05-2016 11:36 AM
Rear wheel brakes adjustment ? JudgeM DIY / Maintenance / Service 8 11-10-2014 03:31 AM
