Old 01-21-2016, 01:32 PM   #1
Decieved
Drives: yaris verso
Need longer wheel studs
Just picked up some new rims and discovered that i need longer wheel studs in order to fit them.
Does anyone know what size the knurled portion is and where i can get some?
I have pressed one out and it measures 12mm but maybe its bigger before getting pressed in?
Also does anyone know the thread size for the four bolts that attaches the rear hubs, it appears to be m10 but i dont know the pitch.
Decieved is offline   Reply With Quote
Old 01-21-2016, 02:14 PM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I used IS300 ARP studs
I just installed them and I have pictures at home where I measured the knurl on them.
http://www.summitracing.com/parts/ar...FdgBgQodEy0B8g
I couldn't tell you the pitch on those bolts. If I am not mistaken, I do believe its the same as the caliper bolts up front.
-Derrick-
Old 01-21-2016, 03:17 PM   #3
Decieved
Drives: yaris verso
Thanks.
Did you drill the hubs or just pressed them in? The ones you link are a good 2mm bigger than the ones i measured, i guess i could ream the holes if i cant find a suiting stud but then i need to know how much undersized the hole should be.
Old 01-21-2016, 04:37 PM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I used lancer evolution studs and everything seemed to fit just fine. They are press fit, the fronts were pretty difficult but the rears were easy.
2014 BSpec Divisional Champion
Old 01-21-2016, 04:51 PM   #5
Jason@SportsCar
Second that on the ARP Mitsubishi Evo studs.
I was able to install mine with a stack of washers, an old lug nut, a socket wrench and some spray lube.
Old 01-21-2016, 05:16 PM   #6
Decieved
Drives: yaris verso
sadly none off those will fit since the knurled portion is to big, might have to get them anyway and ream the holes :(
Old 02-01-2016, 04:05 PM   #7
justjesus
justjesus's Avatar
Drives: 2008 Liftback
did you try the ones noted above? they don't just slip in, they have to be pressed in.
Old 02-01-2016, 08:09 PM   #8
Decieved
Drives: yaris verso
Nope they were 2mm to big to be pressed in, i must have some odd size since mine are smaller. I however found some that were 12.3mm and they pressed in just fine.
Old 02-02-2016, 11:51 AM   #9
justjesus
justjesus's Avatar
ahhh, okay good.
Old 02-05-2016, 11:36 AM   #10
ilikerice
ilikerice's Avatar
This is the knurl on the IS300 studs. 0.003 off from oem.
I can get a pic of the knurl of the OEM one also for reference if you want.
-Derrick-
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
new wheel? Nekofelin DIY / Maintenance / Service 1 08-10-2010 02:37 PM
Leather Steering Wheel MGargano Cosmetic Modifications (Exterior/Interior) 29 05-08-2009 04:53 PM
Help with wheel spacers.. lilred08 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 04-26-2009 07:47 PM
