Old 10-27-2021, 08:42 AM   #1
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
Rear sway bar for 2015 yaris LE
Hello all.
New to the forum but have tools and know how.
Is there such an animal as a Rear sway bar for 2015 yaris LE.
Dealer says no! Anyone have an idea?
Thanks
Calrenman is offline   Reply With Quote
Old 11-12-2021, 01:31 AM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
PTR11-52071 will bolt up to any NCP131, NCP91 or NCP93 Yaris aswell as Scion xD.
Always take anything a dealer says with a grain of salt, they generally don't know the specifics between what interchanges or not unless a computer tells them they do.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 02-07-2022, 05:30 AM   #3
Calrenman
Thanks. I will check it out.
Old 04-02-2022, 08:33 AM   #4
Calrenman
Mitch, do you know if the Strut tower braces and under body braces from the 2013 generation will fit the 1015 5 door Hatchback?
Old 02-16-2022, 01:56 PM   #5
RedRide
RedRide's Avatar
I have an after market sway bar on my 2009 Yaris and it completely improves the handling for the better
You would think that with a solid rear axle it would not do much but, it works amazingly well .
Old 04-02-2022, 02:59 AM   #6
Calrenman
Thank you for the feedback gentlemen.
I just ordered my TRD sway bar/ axile stiffener.
I will have installation Pictures.
I am also exploring frame stiffeners and a front tower brace from, racing_champion on ebay :
https://www.ebay.com/itm/17495755153...torefresh=true
I am also going to lift the car 1 to 1.5 inches because it is too low for the roads in Ventura County! Any ideas?
Old 07-06-2022, 01:05 AM   #7
Calrenman
I just ordered the Tanabe TTB121F Sustec Front Strut Tower Bar For 2007-13 Toyota Yaris Scion xD #133454120095 for my 2015. I hope I have the right one.
I will be installing a front 30mm lift kit, a rear 40mm lift kit, The Strut bar and my TRD sway bar at one time. Anybody think I will notice a difference in handling?
(How are you, Mitch? Thanks for the help.) I will be doing Video/ pics!
Old 07-10-2022, 05:08 PM   #8
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
I have the Tanabe NST45 on my 2014 and it fit like a glove, I'm not sure if the TTB121F will fit. They look the same, so maybe? I bought mine from RHDJapan.
2014 NCP131 5 Speed
Old 07-12-2022, 06:43 AM   #9
Calrenman
I am going to find out! The ends match the holes
Old 07-11-2022, 02:22 AM   #10
sh0rtlife
honest question...as ive never understood the strut tower braces..does it really make that much differance?!?!?! and i mean on the STREET not the track
i mean i guess if the chassis flexes easy then sure...but the the only other strut rig ive owned and hooned was an 89 factory turbo dodge caravan (SWB) and those towers did NOT move and i drove it like i was on an autox on every street i could...that thing didnt know what flex was up front...out back well....it was leafsprun and twisty out back
Old 07-11-2022, 04:30 PM   #11
honest answer... it's bling factor when you pop the hood.
Old 07-12-2022, 12:41 AM   #12
sh0rtlife
thats kinda what i figured...
with all the hard hilly twistys ive been sent on as of late im finnaly starting to feel the lack of rear sway...lugging 100lbs+ back there and its not so bad..but runnin those same curves empty and you feel it roll around
i always assumed the tower braces were bling n track
i suspect youll get more flex from the control arms up front and the trailing arms out back long before any amount of chassis deflection rears its head
tho i question on the 5dr's about any frame rail connectors...
Old 07-13-2022, 05:41 PM   #13
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
It makes my 9 horsepower 1NZ-FE look fast.
2014 NCP131 5 Speed
Old 07-13-2022, 06:30 PM   #14
sh0rtlife
its canceled oout by the fact your not wearing the matching go fast stickers!
Old 07-14-2022, 04:42 PM   #15
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Bet
2014 NCP131 5 Speed
Old 07-11-2022, 01:09 PM   #16
remcafee
for deivingon the street you wont notice anything, you have to be pushing the vehicle to the max to notice any improvement, rear sway bar, and front sub frame ladder braces i noticed the biggest difference
Old 07-12-2022, 06:47 AM   #17
Calrenman
Hello Rem
Does anyone sell subframe braces for the 2015?
Old 05-12-2023, 08:27 AM   #18
Calrenman
Hi I have not been here in a while.
I installed the sway bar and some rubber spring spacers that firmed the ride up and it tracks completely "true" now.
The slop in the rear axle/ trailing arm is gone! TRD sway bar is the way to go!
I also installed a trailer hitch for a bike rack that seemed to stiffen it up too.
rear sway bars for 3rd gen "real" yaris baseballfan416 Third Gen Yaris General Discussion 3 09-27-2020 09:43 PM
FS: Yaris rear sway bar $100 blacksandiegovitz Items for Sale by private party 12 11-03-2015 07:50 PM
Yaris Rear Sway Bar Install ? Spork Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 03-20-2012 09:17 PM
