Old 02-07-2023, 01:00 PM   #1
Compeer
Drives: NCP90 TRD Yaris Manual
RS Intake Manifold,airbox mod and 1zzfe throttle body/injectors
Hey guys I have been planning on doing the 1zz-fe throttle body sway for a while and have been reading up.
Found these guys selling RS intakes saying they produced a little better top end power and torque, it's one of the mods they do in asia.
Here a pick showing the difference, it's funny becasuse there is the mod to increase the size again from the longer version, which they said lowers where you get the torque but will decrease hp and toyota does know what they are doing and the best NA cars have short stacks not long ones.
So I am picking up the intake and airbox today from an RS, Plan is to mod the airbox by removing the ribs, adding a performance panel filter and then enlarging the intake hole and adding an intake trumpet facing down into front bumper from the opposing side as the factory had it so the air is always flowing the same direction. May use some ofther factory car intake pipe to run from airbox to bumper cavity. I want to keep it short so not all the way down into bumper, with the floods I don't need my intake to low
For the intake manifoldI will use high temp plastic or even a wood adaptor plate with some gasket paper to fit a 59mm throttle body ether from a 1zzfe or a 1az as they are both the same size and we dont care about the electronics anyway as we will be following this amazing New Zealand guide https://sergei.nz/toyota-vitz-rs-and...ttle-response/ So will be replacing the insides with the current yari insides of the throttle body and adjusting idle screw.
The 1zz-fe injectors and Throttle body I still need to go to a PickaPart wreckers and take off a car. Injectors will then go and be cleaned and flow matched with new filters and o-rings. Its about $33nzd an injector at local shops here in Auckland city.
Picked up some of the parts yesterday.
Can see the RS Shorter intake and its part number.
Time to MOD! Starting with the Airbox!
Used various pliers and what not to get all the ribbing out I could.
Then started to get serious and cut off the old intake ring to be used on the opposing side as well drilled out a hole for the new intake.
Then I got out the soldering iron and went ham using the plastic pieces I had removed to plastic weld the intake on and to seal the old holebefore sanding it all.
Compeer is offline   Reply With Quote
Old 02-08-2023, 12:41 PM   #2
sh0rtlife
it will be intresting to see if your plan works...and if it does ill be following your path for sure...the yaris suffers from a lack of torque off the hop
Old 02-08-2023, 07:36 PM   #3
Compeer
Yeah I can't wait to hear some intake noise as well, My airbox now works as a trumpet it's going to have way more "DOOOOORT!!!!"
Old 02-09-2023, 01:18 AM   #4
sh0rtlife
do we know if the "rs" short ram was used on any other car as a non RS?...i ask because i swear ive seen the short intake before but i cant place where....prius?
Old 02-09-2023, 03:29 PM   #5
Compeer
Not prius but some of the larger cars got this manifold in 2004-2006 namely corolla variations and the ist for a hot minute.
Seems some of the more sporty corrola variants with 1.5 from 2008 on had them. If it has the shorter manifold it would be worth checking to see if it has the more aggressive vvti solenoid while you are the wreckers too.
Old 02-09-2023, 04:37 PM   #6
sh0rtlife
shit..i actualy found the more agressive VVT on an XA.....maybe thats where i spotted the short ram
but ill be watching all the rolla's now cause torque is where these lil yaris fail
Old 02-09-2023, 07:14 PM   #7
Compeer
Yeah it should be good for a few hp's in the top end,
I will put the airbox on today today and give it a try, I still have the entire stock setup for everything so if I ever want to put her back to stock I have it all put away, this also lets me play and see what I like the feel of most.
Old 02-12-2023, 01:31 AM   #8
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
huh, I didn't realize the manifolds were different.
the USDM 1NZ one is 17101-21080 while the "RS" manifold is 17101-21070. Guess its time to go on beforward and grab one off a Toyota Ractis or Vitz RS lol. I already have a second gen Ractis cluster in my 2014, may as well run a Ractis manifold too
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 02-12-2023, 05:35 AM   #9
Compeer
Have you already done the 1zz-fe throttle body and injector swap?
Old 02-12-2023, 04:21 PM   #10
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
No. Stock injectors and TB, the throttle response doesn't bother me after I swapped in the Lexus IS250 pedal that gets rid of the dead spot and makes the pedal heavier feeling.
2014 NCP131 5 Speed
Old 02-12-2023, 05:01 PM   #11
Neinris
Drives: 08 Yaris 3 Door Hatchback
I've thought of doing the pedal swap in the future. Would you share how you mounted the pedal? Did you make an adaptor plate?
Neinris is offline   Reply With Quote
Old 02-13-2023, 07:33 AM   #12
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
The gen 3 Vitz RS has its own OEM pedal bracket so I just ordered one from RHDJapan. I don't know if it will work in a 2nd gen though.
Part number is 78114-52020.
2014 NCP131 5 Speed
Old 02-13-2023, 02:59 PM   #13
Neinris
Thanks! Does it look like something like this? If so, did it feel weird that the pedal moved forward? The second and third gen's throttle pedals are the same btw.
Old 02-13-2023, 09:25 PM   #14
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Sort of, its metal though and raises the pedal up about an inch which makes it almost level with the brake and clutch, makes heel-toe a breeze. The Lexus pedal I pulled out of the junkyard had that spacer, I didn't end up using it though and threw it out.
2014 NCP131 5 Speed
Old 02-14-2023, 11:53 AM   #15
Neinris
Thanks! I can probably make such an adapter plate. It won't be pretty, but I won't see it so it'll be ok.
Old 02-14-2023, 06:17 PM   #16
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
If I remember right, the bracket was only ~$12 CAD on RHDJapan's OEM store lol
2014 NCP131 5 Speed
Old 02-14-2023, 07:31 PM   #17
Neinris
I'm not sure if you've looked recently, I punched in that PN 78114-52020, but it's no longer available.
Old 02-14-2023, 08:50 PM   #18
It is on eBay. All I can quickly see is Canadian shipping which is as usual, astronomical. Don't know what US shipping would be.
1ZZfe mod info darkMINI Performance Modifications 21 07-12-2011 11:41 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
