Old 12-05-2010, 12:21 AM   #1
darkMINI
Drives: 08 hatch
1ZZfe mod info
What throttle bodies are you guys using for this mod? Year/model and part # would be great. Also is there a write-up on the install?
So far the only part# I have found by searching the site is #22030-OD030 I believe off an older model corolla?
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 12-18-2010, 05:53 PM   #2
darkMINI
Drives: 08 hatch
Wondering if this one would work?
http://cgi.ebay.com/ebaymotors/07-08...item19c1748d6e
Old 12-18-2010, 08:32 PM   #3
has to be drive-by-wire and not cable throttle.
that one should be ok if you do the chip/servo swap
Old 12-18-2010, 10:21 PM   #4
darkMINI
Drives: 08 hatch
Trying to find what year throttle body to use in the different threads in here. I think I saw '06-'08 somewhere.
Old 12-26-2010, 09:38 AM   #5
darkMINI
Drives: 08 hatch
Does anyone know if I can use TB from a 2003 corolla. Engine cover says VVT-i on it.
Old 12-31-2010, 02:40 AM   #6
I'm pretty sure '03 was still cable throttle.
Old 12-31-2010, 06:41 PM   #7
H3LlIoN
Drives: '09 Yarrrr hatch
you're looking for 05 and newer corolla. if you google corolla electronic throttle control you will find more results, since "Drive by wire" actually refers to a steering system, as opposed to throttle. Has to be normal Corolla, XRS was cable controlled. I believe it's through 07 that it will work on the 1nz, but not entirely sure on that.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 01-27-2011, 07:50 PM   #8
cool_beans00
Drives: 2004 Corolla
sorry for the late chime.
just wanted to post up 03/04 and 05XRS were drive by cable
05+ are drive by wire
I have an 04 Corolla =D
cool_beans00 is offline   Reply With Quote
Old 01-28-2011, 05:42 PM   #9
only the 1ZZ throttle body works, so the XRS is irrelevant.
Old 02-03-2011, 05:29 PM   #10
cool_beans00
woops my bad. wasn't thinking
Old 06-20-2011, 10:44 PM   #11
darkMINI
Drives: 08 hatch
Will a 2005 Corolla 1ZZ TB work?
Old 06-20-2011, 10:45 PM   #12
darkMINI
Drives: 08 hatch
found one for $140
Old 06-22-2011, 05:31 PM   #13
str8Yaris
str8Yaris's Avatar
Drives: Yaris Sedan Supercharged
Yup.... I have one on mine.... I luv it.... make sure u adjust the idle screw though, if not it gonna idle all crazy..... lol
Blitz S/C @ 9psi
Vegas meet 2011
http://youtu.be/1IEebCmtvP0
str8Yaris is offline   Reply With Quote
Old 06-22-2011, 06:19 PM   #14
darkMINI
Drives: 08 hatch
Right on str8
Old 06-22-2011, 11:19 PM   #15
str8Yaris
str8Yaris's Avatar
Originally Posted by darkMINI View Post
Right on str8
U will like the performance on it.... make sure u also swap the chips on it....
Blitz S/C @ 9psi
Vegas meet 2011
Old 06-23-2011, 07:44 PM   #16
darkMINI
Drives: 08 hatch
Yep I plan to do the chip swap. Got to find that write-up again on all the steps. I think I'm gonna bypass the coolant too.
Old 06-23-2011, 08:34 PM   #17
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
whats this about a simple TB upgrade?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-24-2011, 02:43 AM   #18
str8Yaris
str8Yaris's Avatar
Yup did the bypass also..... its good...
Blitz S/C @ 9psi
Vegas meet 2011
PINOUT info stereo ozmdd In Car Entertainment + Electronics (audio / video / alarm) 5 12-14-2009 07:52 AM
My latest mod and last mod for awile due to stupid economy and hour cuts.... YarisSedan Cosmetic Modifications (Exterior/Interior) 8 11-18-2009 05:19 PM
$1,600 Government Rebate on Fatt Batt Insulation or Solar Hot Water Systems Info. *MAD DOG* Australia 1 03-27-2009 09:44 AM
manual transmission: to mod or not to mod? tomato General Yaris / Vitz Discussion 34 03-08-2009 10:40 AM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
