Old 08-13-2007, 01:24 AM   #1
Black Yaris
der Zeck
Black Yaris's Avatar
apexi afc
so I have been talkin to another tuner here in town that has a pretty sick Aveo, yeah laugh.... that is what I did, because I have driven an Aveo b4 and know how sluggish they are, but with a CAI & Exhaust then tuned it with an Apexi AFC to mess with some shit with MAP and the injector pulse, shit that was way over my head.... But this was one bad machine with minor modifications, and he said it can easily be done to the yaris even though we have a MAF instead of a MAP, it is the same concept.....
so I may borrow another buddies AFC out of his old car he does not drive anymore and try and turn my ride, it we are sucessfull, I am going to buy the AFC, and post the DIY on the tuning as each vehicle will be a lil different settings from the next.... so lets hope this shit works, cause if I have similar results has him, I may have the baddest N/A 1NZ on the road
Old 08-13-2007, 01:42 AM   #2
go for it!
Old 08-13-2007, 06:20 AM   #3
Nabisco
Nabisco's Avatar
Drives: '08 Honda Fit Sport
Send a message via ICQ to Nabisco Send a message via AIM to Nabisco
Yes you can fine tune a car pretty well with an AFC. It is what I used to put a MAF from a maxima on my nissan. I suggest you get a zietronix wideband kit. This will allow you to datalog your AFRs as well as others like throttle position etc. You can do a very good tune when used in conjunction.
Nabisco is offline   Reply With Quote
Old 08-13-2007, 09:28 AM   #4
Black Yaris
der Zeck
well I don't know what the hell I am doing with an AFC, but I have a few friends at local shops and a Dyno that are more than happy to help :)
Old 08-13-2007, 10:11 AM   #5
Nabisco
Nabisco's Avatar
Even better. You will get a print out of what you are putting down to the ground.
Old 08-13-2007, 10:14 AM   #6
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
afc only tunes af ratio. You need to tune VVT'I and timing as well ;)
Turbo&Auto is offline   Reply With Quote
Old 08-13-2007, 10:26 AM   #7
Black Yaris
der Zeck
Oh I will have the dyno sheet from the tuning of when this is done
I understand the AFC only does the air and fuel, and a VVT controler would be most bennifical..... but no one I know just has a VVT controler just layin around... but I can get ahold of an AFC, if I have good results, then I plan to run it in conjuction with a VVT controller and retune....
I just hope all this shit works cause it would be a fairly inexpensive preformance upgrade
Old 08-13-2007, 10:28 AM   #8
joey1320
joey1320's Avatar
Drives: Yaris LB
exactly.
the afc will only let you lean/rich the fuel mixture by adding/decreasing % values at 6 points on the rpm scale(i think it was 6 )
is the same thing as the simple emanage but the emanage with the support tool gives you a 16 x 16 grid for specific "tuning".
i'm not sure what your friend did but for a n/a vehicle is kind of money wasted. i used the afc twice on civic turbo-homemade kits and it did what it was supposed to but never to the full extend of a true tuning device.
the only way the afc will be of value is if the ecu runs really rich and you can then take some fuel away, then you will see an increase in power but not much really.
good luck man!
joey1320 is offline   Reply With Quote
Old 08-13-2007, 10:34 AM   #9
Black Yaris
der Zeck
like I said.... this is an experiment.... he works for a reputable tuning shop in Columbus, OH... so I am sure he had an AFC laying around, and he was doing the same experiment
http://www.slowmotionmotorsports.com/modules/news2/
Old 08-13-2007, 10:43 AM   #10
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
Hey ~~ Black Yaris
I have a SAFC 2 too it was from my old ECHO
but i still not installed it because i don't have the ECU wiring diagram for
NCP9X Do you have it ??? Thanks
jimcat is offline   Reply With Quote
Old 08-13-2007, 10:49 AM   #11
Black Yaris
der Zeck
Originally Posted by jimcat View Post
Hey ~~ Black Yaris
nope not yet.... that is one of the things he is having his Toyota guy research.... and ain't there some crack for the ECU or something..... I fucking don't know.... he is doing all that, I don't know shit when it comes to motors
Old 08-13-2007, 10:49 AM   #12
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
I wouldnt expect more then 5-10whp at most.....
Old 08-13-2007, 10:56 AM   #13
Black Yaris
der Zeck
I would be happy with that
I have been gettin 5 here 5 there.... all these little things are starting add up, and if I get them properly tuned together it will make them most efficient
CAI
Header
Full Exhaust
Lightened Pulleys
0W30 Synth Oil
75W90 Synth Trans Oil
SSK
Old 08-13-2007, 05:31 PM   #14
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
CAI
Header
Full Exhaust
Lightened Pulleys
0W30 Synth Oil
SSK
I say go for it, if its pretty inexpensive and your friends want to give you a hand then why not. good luck with the tunning
Make sure to post a DIY and the tunning itself with some pics!
It's a Vitz!
Vic-2NZFE is offline   Reply With Quote
Old 08-13-2007, 10:58 AM   #15
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
5 here or there, dyno proven?
Old 08-13-2007, 11:07 AM   #16
Black Yaris
der Zeck
no, not 5 each... I am saying with all those added up... I am probibly lookin at 100 at the wheels, with all the bolt ons... 105-110 after tuning... it do not find this to be too unrealistic
Old 08-13-2007, 11:12 AM   #17
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
you'd be surprised how this motor is un-affected by mods. Goto a dyno :)
Old 08-13-2007, 11:28 AM   #18
Black Yaris
der Zeck
http://www.yarisworld.com/forums/sho...highlight=dyno
just looking at this post here I do not think I am out of line with my #'s
but I will be doing a Dyno b4 and after to give hard #'s so I can post dyno results... so there will be NO estimating on my behalf, only the the Dyno will tell
NEW A'PEXi Exhaust Line up for the 2007+ Toyota Yaris Vic-2NZFE Performance Modifications 13 09-02-2007 06:12 AM
Did anyone installed apexi SAFC ?? jimcat DIY / Maintenance / Service 27 09-02-2007 04:19 AM
Apexi Safc Neo and Toyota Yaris Katana Performance Modifications 2 06-18-2007 08:10 AM
Apex'i I-MONI MC-BPT Sponsors Classifieds Area 0 11-13-2006 03:38 AM
Anyone tried to appy Apexi SAFC or anything similar on their YARIIIII?? oscarying Performance Modifications 25 10-21-2006 09:42 PM
