Old 11-22-2006, 10:09 AM   #1
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
Did anyone installed apexi SAFC ??
I have a SAFC 2 but still pending to install
because I can't find the wiring diagram for my NCP91
also failed to get it at the apexi official web.
anyone can help me ??
thank you
jimcat is offline   Reply With Quote
Old 11-23-2006, 03:45 PM   #2
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
You could search for the diagram for the old Yaris TS(Europe).
I am pretty sure you have the same engine!
Old 11-24-2006, 07:29 AM   #3
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Argee, i think they are the same engine.
but I found the ECU location, socket and wires are different.
anyway, i will try for it, thanks
Old 11-24-2006, 05:12 PM   #4
Katana
Katana's Avatar
The ECU location is in the hood isn't it?
The old one had it in front of the passenger's seat.
Old 06-14-2007, 12:00 PM   #5
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
I hate to bring back an old thread, but how did it work out.
I have an safc 2 laying around and thought why not hook it up. I can't find a wiring diagram for mine. But just curious how yours worked out. :)
Old 06-14-2007, 01:01 PM   #6
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
The SAFC comes with a install booklet and ECU pinouts in it. I'm pretty sure there was a 1nzfe pinout.
Turbo&Auto is offline   Reply With Quote
Old 06-14-2007, 01:05 PM   #7
staticorex
staticorex's Avatar
It doesn't go past 02.
Edit: Okay, I found the Vitz 1nz-fe. This will be the same for the Yaris? I realize it's the same engine and all but still, It is a different car.
Old 06-14-2007, 01:19 PM   #8
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
You can test the wires. TPS should be 0-5v, and increase in voltage when throttle is applied. 12V is easy to test, and so is ground. Try it :)
Old 06-14-2007, 01:58 PM   #9
staticorex
staticorex's Avatar
?? I don't know what that means. :) I'm not good with electrical stuff. I prolly shouldn't be doing this.
Old 06-14-2007, 02:27 PM   #10
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
At least you admit it. I recommend taking it somewhere if you cant solder anyway, DO NOT use crimp connectors!!!
Old 06-14-2007, 03:04 PM   #11
staticorex
staticorex's Avatar
Oh? It came with them.
Anyway, I just took off my ECU, which was a chore in itself, and I don't know what the hell I'm doing. I don't know of anyone around here who does that kind of stuff either.
If anyone has any better installation pics than what Apexi gives with the SAFC-II I would greatly appreciate it.
I'm off to see if my car will start or if I broke something.
Old 06-14-2007, 05:59 PM   #12
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
Where are you located?
Old 06-14-2007, 06:01 PM   #13
staticorex
staticorex's Avatar
South Central PA.
Old 06-15-2007, 08:36 AM   #14
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
Pay me a lil bit and I will do it for you, I'm in the pocono area.
Old 06-15-2007, 10:16 AM   #15
staticorex
staticorex's Avatar
Really? Hmm. sending pm :)
Old 06-18-2007, 08:07 AM   #16
Katana
Katana's Avatar
Any news?
Old 06-18-2007, 11:28 AM   #17
staticorex
staticorex's Avatar
Yeah. I gave up. It's way too complicated for something that would yield gains too small. Unless I find some really good diy pics I'm done. :(
Old 06-18-2007, 11:43 AM   #18
Katana
Katana's Avatar
Τοο bad.I thought that the wiring diagrams were easy to find.
PICS OF TRD INTAKE INSTALLED! elsteverino889 Performance Modifications 9 03-03-2007 04:12 PM
Anyone tried to appy Apexi SAFC or anything similar on their YARIIIII?? oscarying Performance Modifications 25 10-21-2006 09:42 PM
Tanabe Concept G Exhaust Installed Toddhata Performance Modifications 65 10-06-2006 06:19 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
installed head unit... punch In Car Entertainment + Electronics (audio / video / alarm) 16 06-29-2006 12:06 AM
