Old 08-21-2007, 02:05 AM   #1
ddongbap
High rate springs.
Anyone running higher rate springs? I know Tien comes with 3kg or so, but I'm talking about 8kg.
Old 08-21-2007, 02:52 AM   #2
that'll be coil overs, some (i think the Tein Basics are still in the 3.0kg range). the S.Tech's are 3.0kg in the front and 3.5kg in the rear.
Old 08-22-2007, 02:14 AM   #3
Bdaslug
Bdaslug's Avatar
Drives: 07 Yaris 04 TSX
Yeah I'm running A lot higher spring rates, but I have coilovers, its 12K in the front and 10K in the rear. The setup is more for the track. I'm using HKS coilovers in the front and Apex in the rear.
Bdaslug is offline   Reply With Quote
Old 08-22-2007, 02:25 AM   #4
03Z33
03Z33's Avatar
Drives: TCR10
Nice setup I havent' seen anyone else running those coilovers out here yet.
I'm running 8K front and 5K rear on my SK RMA8 coilovers, it's a nice balance between daily comfort and great handling on the track.
Old 08-22-2007, 02:51 AM   #5
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Werd. Very good looking setup. Those HKS front coilovers look great.
Are those front endlinks available seperately?
Old 08-22-2007, 05:32 AM   #6
Bdaslug
Bdaslug's Avatar
I can find out about the endlinks for you.
Old 08-22-2007, 03:20 AM   #7
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Cusco Compact-S coilovers spring rate is about 7k in the front and 3k in the rear. pretty comfy for daily driving with a bit of hard turning and what not. never tracked it but I want to.
Old 08-22-2007, 04:02 AM   #8
CKMotorsport
CKMotorsport's Avatar
Drives: Yaris
Aragosta Suspension
Agarosta can make special order for racing suspension. you can adjust front and rear shock absorber height (not only from the spring). spring rate you can choose from 6K to 18K
and you also can buy options for damping adjuster (2 way or 3 way type) for the 3 way type it's include Sub tank.
here is some picture. If you interested, and cannot find it in US. I can get it for you.
CKMotorsport is offline   Reply With Quote
Old 08-22-2007, 03:50 AM   #9
i think i would like 03Z33's set up.
Old 08-22-2007, 04:09 AM   #10
ddongbap
Er, sorry. I ment to say after getting some coil overs. I left out coil overs, cause I'd want something thats a bit stiffer, as far as shocks. But i was wondering if anyone made high kg springs first.
Old 08-22-2007, 04:24 AM   #11
CKMotorsport
Drives: Yaris
what coilover kit r u using right now? You can buy the universal spring, but you have to make the spring adaptor.
Old 08-23-2007, 04:50 AM   #12
ddongbap
To be absolutely honest, I don't own a Yaris. I'm planning on getting one within two weeks. But I'm trying to do some research first.
TANABE SPRINGS C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 11-20-2008 08:38 PM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 06:43 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 07:17 PM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 06:08 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 01:23 AM
