Old 09-06-2007, 10:43 AM   #1
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
Unhappy Help me install a converter to HU
I bought a converter thing at Best Buy that I'm supposed to connect to the existing speaker wires coming out of the head unit and it will convert the signal into rca so that I can plug my Infinity Basslink in. The speaker wires are not labeled. Before I go tearing my car apart to get to the speakers and figure out which color goes where and which is - and +, I was wondering if anywhere there is a list telling which color wire goes to which speaker and what colors are the - and +.
PLEASE HELP ME!!! I get my Basslink today and I'm not going to be able to install it
wsladaritz is offline   Reply With Quote
Old 09-06-2007, 10:55 AM   #2
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
I was looking for the exact same thing, they told me to search... couldn't really find it so meh i was going to check the service manual later unless i buy the output jacks from someone...
Old 09-06-2007, 01:31 PM   #3
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
well if you find anything let me know please :)
Old 09-06-2007, 03:40 PM   #4
duck
Drives: 2007 Silver Sedan
the best way is to spend a couple of hundred or more on a new headunit that already has RCA outs.
if the subwoofer and amp are going in the trunk, the easiest way is to tap off of a rear speaker. I haven't seen on the yaris, but it could be obvious which is +/- or you can guess.
another option is finding a toyota wiring harness in a store and reading the instructions, since that lists what each wire goes to and you can then determine which to use for your purposes.
most likely, it's in one of the guides on here or somewhere. I'm having trouble identifying wires for my headunit install as well, so unfortunately that's all the help I can provide.
duck is offline   Reply With Quote
Old 09-07-2007, 01:57 AM   #5
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
FOUND IT!!! And ended up not needing the converter... the infinity basslink comes with 4 speaker wire inputs that you can just splice with the existing speaker wire. And it sounds amazing!
http://modifiedlife.com/stereo-radio...-toyota-yaris/
Old 09-07-2007, 06:54 PM   #6
punch
punch's Avatar
just a note, the colours are different in the sedan....
out of respect for nutzoid, I changed my avatar.
punch is offline   Reply With Quote
Old 09-07-2007, 08:31 AM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Congrats on finding what you were looking for....I ran my 10200 bazooka on the factory HU for about 6 months before putting in my Pioneer Premier....believe me when I tell you that I really missed what it sounds like with a clean composite link rather than splicing off the speaker wires. It really is a phenomenal difference and my tube has a lot more punch when on the composite...I would wager to guess that it would be the same with any powered sub....just a thought.
Old 09-07-2007, 10:44 AM   #8
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
I might replace the HU with something new... sometime... very distant in the future :(
Old 09-07-2007, 01:01 PM   #9
Nexus1155
Drives: Audi
you could always get the line inverter anyways that a member from the scion board sells... its like $40 and taps into the stock head unit and gives you a remote and rca jacks.. kind of cool if you ask me...
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
New CAT Converter story.... jlift DIY / Maintenance / Service 14 06-03-2007 01:23 AM
High-to-low converter Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 11 05-21-2007 01:18 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
