Old 08-04-2007, 11:22 PM   #1
RocknRollRon
Drives: '07 Yaris LB, White (The Egg)
Looking for the Toyota Fog Light install
Does anyone out there have a copy of Toyota's offical install directions for the factory fog light accessory?
I'd like to stay as true to the factory install as possible. I tried looking through tundrasolutions.com but didn't find a match...closest was the Matrix instructions... :-(
A pdf copy would be much appreciated...
RocknRollRon
Somewhere in New Jersey or beyond
RocknRollRon is offline   Reply With Quote
Old 08-04-2007, 11:39 PM   #2
DMart
same amount of posts lol
DMart's Avatar
Drives: 07 Meteorite Metallic LB
http://www.yarisworld.com/forums/sho...ight=foglights
this is what everyone here has done, including myself...works perfect, no problems
DMart is offline   Reply With Quote
Old 08-04-2007, 11:59 PM   #3
RocknRollRon
Thanks...already saw this and it looks great but i'd like to get my hands on the toyota install instructions if possible...call me anal...lol
RocknRollRon
Old 08-05-2007, 12:02 AM   #4
ok... you're anal. (oh wow, I said "anal"). LOL
Old 08-06-2007, 12:29 AM   #5
meteoriteyaris
meteoriteyaris's Avatar
Drives: 2007 Meteorite metallic
I agree. I've been reading all the posts on the OEM fog lights that everyone is installing, but they are not using the factory wiring harness. I'd think they are all wired for fog lights at the factory so the dealer can add them later. We need to see the factory connect points so the installation would be a lot faster/easier plug-n-play instead of running another harness inside. Any Toyota techs out there that's done this upgrade?
meteoriteyaris is offline   Reply With Quote
Old 08-06-2007, 12:52 AM   #6
DMart
DMart's Avatar
with the fogs i had i couldn't use the clips didn't have anywhere to connect to on the car, i guess b/c i don't have any power options, or maybe its just a u.s. thing??? i looked all over in there for a factory wires for fogs to just plug-n-play but didn't find any...
Old 08-06-2007, 08:08 AM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
I found where just just plug the wires in..... how come every one else could not? I got the same ebay kit everyone else did.... well the one from Jimcat...
Old 08-06-2007, 08:32 AM   #8
Black Yaris
der Zeck
Old 08-06-2007, 08:37 AM   #9
Black Yaris
der Zeck
BTW I am extrememly anal retentave as well, and that is why I did my install as pictured above... I wanted the wires to look as stock as possible and I ran them as I thought the factory would, well with what I had to work with...
also I removed the DRL bracket (since I disabled them a long time ago) and mounted my foglamp relay there, and used one of the dash braces for the ground.
Old 08-06-2007, 04:43 PM   #10
meteoriteyaris
OK, I haven't received my fogs yet, but I assume they'll be the same as everyone else's even if I didn't buy them from Jimcat (it still says OEM and got them off ebay). I had the front clip off to install a tow-plate (I'm going to tow it behind my motorhome...yes, Toyota says it's OK right in the manual (5-speed LB)) and saw a lot of wires under there not connected to anything, so I assumed the harness was there to plug into. However, everyone on here seemed to go right to running the new harness and I kept reading the posts and wondering if they were missing something. Ok, Black Yaris, you say the wiring (U.S. car) IS all there and you just plugged in, right? HOw about the switch, is there a plug-in under the console? Where did you find that junction block you plugged your wires into? Wasn't there factory plugs for everything? I'm still confused. You say you were able to do what no one else has done, but it still looks like you had to run some wires somewhere. How about a better explanation, maybe pictures?
Old 08-06-2007, 08:07 PM   #11
RocknRollRon
Ok Black Yaris: I'm electrically challenged and don't know the location of you pic. Please describe location...thanks
Jimcat's fog lights are due here this week...I'm not in a hurry to install them so I'd like to gather all my options first - including seeing the dealer install directions...doesn't anyone out there have a copy!!!?
RocknRollRon
Old 08-07-2007, 01:23 AM   #12
Black Yaris
der Zeck
OK RocknRoll..... That picture is taken from the the area behind the change tray that pulls out rught under the cup holder on the drivers side, the whole tray will pop out and you will see what I have pictured... now you will have the white wire and red wire as part of your fog lamp kit, but they will have the wrong plastic connectors on them, so you need to take the wire and pin out of the connectors, and place the white one where I have pictured and slide the red one into the existing connector as I have pictured..... this will make it so your lamps will only be on when your ign is on, so it will never drain your battery
Old 08-07-2007, 01:40 AM   #13
DMart
DMart's Avatar
i wish i would've done that instead of tapping into the outlet in the car...
Old 08-07-2007, 01:42 AM   #14
Black Yaris
der Zeck
I try and do things with out damaging my car first.... if I would have had to splice, I would had..... but I would have tried a bunch of alteratives first
Old 08-07-2007, 01:50 AM   #15
DMart
DMart's Avatar
lol, yeah, thats smart....i'm a rookie tho...lots to learn...
Old 08-07-2007, 06:29 AM   #16
RocknRollRon
Thanks Black Yaris for your help. I also found the drawings and electrical diagrams in the downloaded manuals. Luckily I know someone at work to help me through understanding them....
In one of the diagrams it shows a connector to the right of the module you have pictured. It is labeled for the foglights! Is this the ACTUAL place the Toyota lights would plug in with the right connectors? If so, is there a connector that can be beg, borrowed, or stolen to make Jimcat's unit plug right in?
(Still searching for the offical Toyota install on the Fog Lights)
This is a challenge to my fellow members...can you obtain a copy?
RocknRollRon
Old 08-07-2007, 09:49 AM   #17
Black Yaris
der Zeck
you will just have to buy a set of accessory Toyota fog lamps photo copy the instructions and return them the same day, and say someone already bought them for you or something
Old 08-07-2007, 01:30 PM   #18
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
and paste a copy in here so we can all look at it!
the_boss is offline   Reply With Quote
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 09:45 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
