Old 11-18-2006, 02:59 AM   #1
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Engine Swap
Question...
Would a Toyota 2ZZ-GE2 engine fit into a Yaris?
Why spend $2,500+ on a turbo that might not fit, when I can spend $3,000 on an engine that spits out 180hp?
ANYONE????...
Nutzoids is offline   Reply With Quote
Old 11-18-2006, 04:58 AM   #2
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
Send a message via MSN to Teruyume
So how much u gonna spent on installation labour, plus parts fabrication?
Assume:
Engine removal & install 16hr@$50/hr $800
Custom Wiring Shit 5hr@80/hr $400
Custom Engine Mount 3 pieces @300 each $900
Custom Drive Shaft 2 pieces @400 each $800
Custom AC line, Rad hose, Heater hose, Vaccum lines, intakes...etc $500
Plus a bunch of unknow stuffs, wut about $1000
u are looking at $4400 on top of ur $3000motor. Now u got yourself a 180HP yaris........ wow wut a deal............lol
how about Blitz Compressor $3000
full internal w/ piston&rod $1500
Head job w/oversize valve & spring $1000
Injectors $800
Engine removal $ install 16hrs@50/hr $800
ECU flash and tune 5Hr@80/hr 400
$7500, u got yourself a Race Motor with over 200WHP how's that lmfao
06 Yaris RS 2Dr HB 5MT Orange
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Kumho Ecsta AST 195/50R15
Tanabe DF210
JDM LED Tail lights
Teruyume is offline   Reply With Quote
Old 11-18-2006, 06:57 AM   #3
TRD Thailand quoted about $3000 for the swap including the engine, all labor and parts, so it's quite a viable alternative here. But it would take them about a month or more, as the whole engine bay needs to be modified to fit the engine. And, the engine would be a refurbished one, not brand new.
But, the 2ZZ-GE is a very interesting engine, redlining at 8000+rpm if I am not mistaken... Plus you could always add a turbo or supercharger later, if there's any space left in the engine bay, and look at some pretty crazy power...
And, apparently the 1.8L Yaris TS will be eventually available here too, so that's another option for an engine, wait and see!
Old 10-01-2007, 06:07 PM   #4
MPG-brian
Drives: Toyota Matrix XRS
better than 2zz...swap the 2zz into your yaris, add a hydra ems ($1500), then you can lower the 'lift'. then you will have more hp available sooner than 6400 rpm like in corolla, matrix, etc.
www.mpg-motoring.com
MPG-brian is offline   Reply With Quote
Old 11-18-2006, 11:50 AM   #5
dngz
dngz's Avatar
Drives: black yaris sedan
how big is the engine? the engine bay seems so cramped even with a teeny weeny inline 4 banger..!
dngz is offline   Reply With Quote
Old 11-18-2006, 12:29 PM   #6
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
the engine and tranny is too big to fit in between the Left and Right Front unibody.............seriously don't think distorsion of unibody is smart
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Tanabe DF210
JDM LED Tail lights
Old 11-18-2006, 04:30 PM   #7
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Ι have thought of it too.
In Europe, this engine has 192hp and the limiter is at 8800rpm!If I could find a brand new one, I would do it!
Old 11-18-2006, 07:16 PM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
[edit] 2ZZ-GE
2ZZ-GE Engine in the Corolla XRSThe 2ZZ-GE is a 1.8 L (1796 cc) version built in Japan. Bore is 82 mm and stroke is 85 mm. Output is 180 hp (134 kW) at 7600 RPM with 130 ft·lbf (176 N·m) of torque at 6800 RPM. It uses MFI fuel injection, has VVTL-i, and features forged steel connecting rods. Compression ratio is 11.5:1. Unlike others in the ZZ family, the 2ZZ-GE requires "premium" gasoline - 91 octane or above in the USA. Power output for this engine varies depending on the application and tuning, with the Lotus Elise and Lotus Exige offering 190 hp but the Pontiac Vibe, Toyota Corolla and Toyota Matrix versions only developing 180 hp (+2005: 170 hp). The Corolla Compressor and Lotus Exige S add a supercharger to achieve 215 hp, while the Exige 240R's supercharger increases output to 240 hp.
The 2ZZ-GE utilizes a dual camshaft profile system (the "L" in VVTL-i, known by enthusiasts as "lift"), to produce the added power without an increase in displacement or forced induction compared to the lesser engines in the ZZ series. This is similar in concept to Honda's i-VTEC, but the two systems are very different in design and execution.
Toyota commissioned Yamaha to design the 2ZZ-GE, and it shares several similarities with street bike engines, the most notable being the relatively high RPM design. The high-output cam profile is not activated until above 6000 RPM (the exact point of engagement is different depending on the vehicle, year, and ECU involved). On all of the Toyota-built vehicles, redline begins at 8200 RPM while the tachometer is typically numbered to 9000, giving an incredibly small "unusable" range. The Toyota ECU electronicly limits RPMs (through fuel and/or spark cut) to ~8200 - it is impossible to "over-rev" the engine with the throttle alone, a downshift from a higher gear is required. The motor will happily run at ~4000 RPM for extended periods of time, and during stress testing the motor will be run at redline for extended periods without issue. For the first few years of production, the engines were notorious for breaking off the "lift bolts" inside the engine. This didn't do any damage, but did hamper performance, as the high output cam profile would not engage properly. Toyota fixed the problem in late 2002, and there is a TSB for dealers showing what bolt to replace and the redesigned bolt.
Applications:
Toyota Celica SS-II (Japan, 190 PS)
Toyota Celica GT-S (USA, 180 hp)
Toyota Celica 190/T-Sport (UK, 189hp)
Toyota Corolla Sportivo (Australia, 182 hp)
Toyota Corolla Compressor (Europe, 215 PS)
Toyota Corolla XRS (USA, 170 hp)
Toyota Corolla Fielder Z Aero Tourer (Japan, 190 PS)
Toyota Corolla Runx Z Aero Tourer (Japan, 190 PS)
Toyota Matrix XRS
Pontiac Vibe GT
Lotus Elise (North America/UK)
Lotus Exige (US/UK)
Old 11-18-2006, 07:23 PM   #9
spkrman
Drives: 1
power is way too high in the RPM range for me.
Old 11-18-2006, 07:25 PM   #10
spkrman
Drives: 1
perhaps I'll raise the question, if this motor is a headache to install in a yaris, what would be a better motor to swap?
Old 11-18-2006, 07:32 PM   #11
I would guess the engine being used for the Yaris TS would be a better fit, though I am not sure what model it is.
A 2JZ-GTE would be pretty sweet though
Old 07-23-2007, 09:45 PM   #12
regime
Drives: 95 volvo 850 (saving my cash)
Oh god all you need to do is sound like your from California, and say "2jz no shit".... and hey why your at it... you could mention "overnight car parts from japan".... :COUGH:
regime is offline   Reply With Quote
Old 11-18-2006, 07:36 PM   #13
Black Yaris
der Zeck
a 2jz-gte with a rwd conversion, would a be kick ass lil drift machine
Old 11-18-2006, 10:17 PM   #14
raz0rbladez909
Drives: 3 door yaris
a yaris drifting that'll be the day lmao
raz0rbladez909 is offline   Reply With Quote
Old 11-18-2006, 10:47 PM   #15
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
http://www.yarisworld.com/forums/sho...ghlight=tacoma
Scroll about half way down.
'06+ Toyota bB
Garson - D.A.D. aero
Zuenglein Dolci wheels
the_saint is offline   Reply With Quote
Old 11-20-2006, 02:51 PM   #16
spkrman
Drives: 1
any updates here?
Old 11-24-2006, 02:07 PM   #17
thefoth
Project Sideways Yaris
Drives: 2007 Toyota Yaris 3 Dr RWD!
Send a message via AIM to thefoth Send a message via MSN to thefoth
Originally Posted by spkrman
any updates here?
No updates as of yet. Head over to http://www.mospeed.com/yaris/ to follow for updates.
We are currently working on developing the braking system, suspension, a body kit, and building the engine.
If someone is looking to just do a swap in their Yaris I would recommend contacting http://www.whyindustries.com, http://www.turbotoyotas.com (related groups)
They already have developed a number of swaps for the xA, xB platforms and it would only take them a couple weeks to make new mounts for the Yaris. They also have a turbo kit developed for the 1nz-fe.
It doesn't look like there is any contact info up on the site yet, but I do have it if anyone is really interested.
As far as Project Sideways Yaris is concerned, the engine selection was based of a very basic idea. We wanted to present to Toyota that they could build an affordable RWD car for under $20k by utilizing parts that are EASILY available from other Toyotas. There are thousands of base model 2wd, std cab Tacomas , thus thousands of 3RZs and the Yaris is a very affordable platform so putting them together for an OE shouldn't cost very much. Second to that, the 3RZ is a very strong engine, it is used in the RWD tC drag cars and produces upwards of 1500hp. Our target for Project Sideways Yaris is 300-400hp. Though the 3RZ doesn't have the prestige of the 3S-GTE, 4A-GE, or the 2JZ-GTE... it will be more than capable of handling the task.
Hope that answers the questions.
Peace,
David
Project Sideways Yaris Manager
thefoth is offline   Reply With Quote
Old 04-23-2007, 11:32 PM   #18
weaponrcamry
Drives: Camry LE/Yaris Hatch 5spd
I would do the 2zz swap, 4age, or the 1zz swap. But the most up to date motor is the 2zz or the 1zz. It would more smaggable if you are having trouble with emissions, and a visual check. I have also found out if you are doing the swap is that the sedan has more engine room than the hatch(LB). With the 2zz swap their would be no air condition, you would have to basically go into the floor boards, cut back into the firewall, make a new wiring harness, plumbing, drive shafts, frame rails and the list goes on and on, probably the same thing with the 1zz. Unless you like to do custom work go for it. But what comes to mind is that people from japan or overseas get the 1.8 dual vvti so if somebody can look closely to their interior and engine bay a compare that car from yours that would sure help out a lot. I want to do a swap or turbo. More linear toward the swap. Please help.... If nobody checks out these specs, I guess I am going to wait until the scion XD comes out and look at their engine bay, since it shares that same platform as the yaris.
The 1nz-fe.. Just rebuild that, more room for turbo, you get air condition, cheaper to do in my opinion...
|.....Overnight.........................| ||
|........Parts From Japan.............||'|";,__
|_..._...____________======||_|_|....,,]
weaponrcamry is offline   Reply With Quote
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
Aftermarket engine dipstick sroberts General Yaris / Vitz Discussion 1 08-10-2006 09:44 PM
Engine Working too hard? David81 General Yaris / Vitz Discussion 8 06-14-2006 11:17 AM
Noisy Engine David81 New YARIS Purchase Forum 8 06-02-2006 12:15 PM
