My Little Blue Egg :)
Drives: '09 3 door Yaris Join Date: Dec 2008
Problems?
Okay, so i bought my 2009 Toyota Yaris at the end of October of this year. So i've had it for like, 2 months.
The brakes have become very mushy, to the point where i have to forcefully push them as far as they can go to stop the vehicle at any given speed. One morning I was doing around 25 mph, and the car just wouldnt go any more, so i pressed the pedal down far, and nothing happened..so i pulled over..just checked things out, and it was fine after that. So I take it back to toyota, I have them check it all and everything, and they stood there and called me crazy and said nothing was wrong with the vehicle. Has these problems happened to anyone else? And also, does anyone have problems with the automatics not shifting after 40 mph? |
Parallel Parking Pro
Okay, it sounds like you have a lemon. Drive it to another Toyota dealer to have it checked out. They can't be the only Toyota dealer in your area.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#3 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
PLEASE CHECK OUT THIS SIMILAR THREAD!!! <<<<CLICK |
#4 | |
Drives: yw calls me douche and racist. Join Date: Aug 2007
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
![]() ![]() Drives: 08 Polar white hatch Join Date: Oct 2008
It is because you did not let it warm up upon starting it. The "cool temp light" on the dash must go off before driving. It will not shift properly and stays in 3rd gear. I think it is a MAJOR safety issue and am probably going to get rid of my yaris for this issue.
Another STUPID idea from toyota... |
#7 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
It's also better to drive the car slowly as soon as you start it versus idling. Better for fuel efficiency and better for the maintenance of your car. Seems like you hate a lot of things about your Yaris. I suggest you research and test something better before you buy it next time. Sure, the Yaris is far from perfect and some things about it annoy me (The warm up feature which prevents proper shifting until a proper engine temp is reach, included), but the Yaris is a great car for what it was intended to do. |
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
#9 | |
#10 | |
#11 | |
Once I had the floormat interfere with the brake pedal. Barely stopped for a stop sign.
help! my Yaris shrunk!
Drives: 12 Hot Lava iQ/07 Jade Vios Join Date: Jun 2007
#14 |
#15 |
╚══════════RN
Everyone must be really stressed out from christmas shopping or something, it's like a 24/7 whine-fest, pitty party, bash-o-rama around here lately.
#16 |
Small Car Lover
The warming thing with the auto is for emissions reasons. When your car is cold it emits worse fumes than warmed up. So the tranny doesn't up shift into the overdrive gears until it reaches a certain temp. It helps the engine warm up faster. With my ECHO i Have this. Its annoying but oh well, as long as the car starts and keeps going I can't complain.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will. |
#17 |
#18 |
P.S. most cars with an auto trans lockout the highest gear and hold the lower gears longer when the engine is cold, like another member said, its to heat the engine up quicker by forcing it to work under a greater load untill it is warm. Every car that i've owned with a fuel injector system has been like this. Its not a safety concern, the car will go just as fast as it would with the top gear its just going to rev a lot higher to get there and may seem like it doesn't want to, though thats simply the car and the mfr telling you not to really push it with a cold engine. Buying any other car on the market in the US with an Auto trans will get you the same feature you complain about on the Yaris, do your homework before you put yourself thru a lot of wasted time and money getting a new car just because of this.
| HELP WITH NEW 2007 PROBLEMS | partenac | General Yaris / Vitz Discussion | 15 | 05-31-2007 05:06 PM |
| some minor problems after installing my HID kit, any professionals? | ASHRAF | DIY / Maintenance / Service | 14 | 03-09-2007 10:54 AM |
| headlight problems | KSIbucky | DIY / Maintenance / Service | 2 | 02-28-2007 10:54 PM |
| Timing chain, sprockets, & cam position sensor problems? | PetersRedYaris | DIY / Maintenance / Service | 8 | 01-04-2007 11:50 AM |
| major problems? | kaymm | General Yaris / Vitz Discussion | 3 | 09-18-2006 08:25 AM |
