Old 01-14-2009, 09:45 PM   #1
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
who removed their VVTI engine cover?
was thinking if it would ok to remove it and drive without it
i was thinking it could be cooler for the engine
Yawesh is offline   Reply With Quote
Old 01-14-2009, 09:51 PM   #2
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
yeah, won't hurt anything
Wanted: Forced Induction
Old 01-14-2009, 09:58 PM   #3
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
Won't hurt at all. Can't think it will do a whole lot of good either but what the hell
DFA is offline   Reply With Quote
Old 01-14-2009, 10:16 PM   #4
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Does removing it actually help keep the engine cooler (you know, because the cover is off so there wouldn't be like a "warm blanket" effect)?
Old 01-14-2009, 10:24 PM   #5
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
danx ppl
Old 01-14-2009, 10:24 PM   #6
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
The cover seems to be for noise suppression (and hiding the wiring mess) more than anything else. My engine seemed louder after I took it off; but after a few days I got used to it and didn't even notice it anymore.
Old 01-15-2009, 12:23 AM   #7
gid
+1 on more valve noise ...
when I removed the plastic engine cover on the 2000 Chevy PRIZM ( Corolla ) to replace the P.C.V. valve , I decided to leave the cover off to see if would help it run cooler during the summer and the valve noise got louder . Put the cover back on and got quieter . Did this several times to double check and remained loud without it , especially when on the interstate ( high speeds ) . The other 1/2 noticed it as well and told me to put it back on , which I did . If you do remove it , pull out the plastic push ins of the engine cover out when the engine is cold , otherwise they'll break off in the pre-drilled hole of the valve cover . Learned this myself , had to use a sewing needle to pry it out and buy another push in at dealer . Luckily not too expensive and had them in stock . I think it's usually a special order item .
Old 01-15-2009, 12:58 AM   #8
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
never mind then, i alraedy think the yaris is loud already......i can now imagine if i removed it
Old 01-15-2009, 12:28 AM   #9
gid
if traveling in heavy slow moving traffic it may be worth it to help it remain cooler . Then use a synthetic as well to help tame the noise with / without the cover . All in the ears of the beholder .
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Painted Engine Valve Cover: Round 2 m911gt Cosmetic Modifications (Exterior/Interior) 46 01-12-2009 08:17 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
Toyota Yaris Scion xB xA Stock ENGINE COVER OEM justoneyaris Items for Sale by private party 11 12-04-2008 08:05 PM
CF'd my engine cover Turbo&Auto Cosmetic Modifications (Exterior/Interior) 16 06-18-2007 08:03 AM
