Rides canyon walls
Drives: 1988 RX7 FC 10th AE Join Date: Jun 2007
Spilled oil on engine
Dont ask how this happened, but I like spilled a bunch of oil around the err engine bay area. I tried to clean as much as I could, mostly what I could see. Umm, so like I went to drive somewhere real quick and I can smell some oil burning. Is this ok or is it really bad?
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header |
Only Happy When it Rains
as long as you are sure you put the plugs back, if you spilled oil on the engine, it will burn off. Might as well double check to make everything is where it should be, and if it is you'll prolly smell that unless you do a super thorough cleaning.
Colin Chapman disciple |
Rides canyon walls
I'll do an even more thorough cleaning tomorrow. I dont do a lot of driving, and when I do its short distances so I think it should be ok for the time being.
Go to a car wash and wash it off, just be careful using a pressure washer under the hood. Avoid letting the spray hit any electrical connections, bearings, etc. If it's just oil running down the block that should be simple.
Simple Green is a safe way to get rid of oil.
2007 Silver Streak Mica Yaris S Sedan 5 Speed dojo TSUKAMI Shift Nob Brake Light Pulser Daytime Running Lights http://www.webelectricproducts.com/products.htm |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
yup , + 1 on simple green or window cleaner . Use that for cleanup during oil changes , dissolves very well .
can of brake cleaner will do wonders. Its the staple of any lube shop. Cleans oil spills in a jiff. I think my shop uses 3 boxes a week.
Rides canyon walls
Cool, thanks so much for the advice guys. Hopefully it isnt too cold tomorrow morning for me to get out and clean this stuff off.
Audio Junky
first time changing your oil yourself ??? :-)
Rides canyon walls
Oh no, not at all I've done every oil change myself since I got my car. I did something a little more embarrassing than that...
![]() ![]() BTW I cleaned it up very well and there is no longer that burning smell. Plus it looks good as new now. Thanks for all the help.
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
It'll smell like carbon heating up, it'll act like a shit-magnet for dirt, but that's about it.
#12 | |
| leaky seal on engine? oil overfill? | jeff69dini | DIY / Maintenance / Service | 23 | 06-07-2010 12:52 AM |
| Engine oil ddi not come out | hans_fh | DIY / Maintenance / Service | 18 | 01-23-2009 11:30 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
| About Engine Oil Changing Manual | hans_fh | DIY / Maintenance / Service | 4 | 03-03-2007 10:20 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
