Old 01-27-2009, 07:59 AM   #1
FA7
Drives: 2008 YR 5 door
Proper offset?
Hey guys, i am looking at 17's for my yaris hatch, YR, The rims i am looking at are a 4x100 with a 42 offset, basically want to know if this is the correct offset for the car...
The Mach-10's
http://www.tenzoracingsports.com/main.php?page=wheels
FA7 is offline   Reply With Quote
Old 01-29-2009, 01:45 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Yup, ET42 will work just fine. Some nice wheels there. Which ones do you plan?
Old 01-30-2009, 07:31 PM   #3
FA7
not 100% sure yet, but looking these 3.....
Old 01-30-2009, 08:42 PM   #4
kimona
kimona's Avatar
Those 3 styles are nice. I'm partial to the mesh and multispoke designs. Hmmm... I guess the mesh win out for me.
Old 01-30-2009, 08:53 PM   #5
FA7
all the rims come in 17" in a 4x100 configuration with a 42 offset, won't fit?
Old 01-30-2009, 10:09 PM   #6
kimona
kimona's Avatar
Yes. 17x7, ET42, 4on100 will do just fine. Run 205/45/17 on stock suspension or with a mild drop.
Old 01-31-2009, 12:58 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
on stock suspension or with a little bit of camber, you can easily run a +35 offset.. it'll give you a very nice flush look. 205 tire MAX though.
Old 01-31-2009, 03:27 PM   #8
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
although if you lower the car with the +35mm you run the risk of rubbing.
EDIT: why did you choose tenzo if you don't mind me asking?
Russelt3hPirate is offline   Reply With Quote
Old 01-31-2009, 03:32 PM   #9
Black Yaris
der Zeck
Black Yaris's Avatar
that is not true in the slightest, we can run pretty low offsets on Scions with out rubbing
I run 17x7 +18 front and +5 rear.... with 205/40R17.... I am lowered 3 inches, no rubbing problems.
Old 01-31-2009, 03:48 PM   #10
Russelt3hPirate
l33t3st Asshole
congrats, you have a scion xB.
does the OP?
I run a 15x7 +35mm on my YARIS and it rubbed when lowered until we put coilovers on. I have a feeling that's a little more applicable then your scion when regarding the OP's setup.
Although I could be wrong....
Old 01-31-2009, 07:15 PM   #11
FA7
went to the local showroom here in adelaide and loved the look of the black rims, non of the other black rims they had i thought looked good, if you can suggest other rims i am more than happy to look at them as i am always changing my mind
Old 01-31-2009, 08:15 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
i recommend Team Dynamics (the racing line, not the "street line") an excellent UK-made wheel and comes in decent offerings for width and offset. simple designs, strong, and relatively lightweight
Old 01-31-2009, 03:59 PM   #13
Black Yaris
der Zeck
well you were commenting to Tamago.... also a Scion owner
Old 01-31-2009, 04:02 PM   #14
Russelt3hPirate
l33t3st Asshole
who was commenting about the OP. come on, I know you're smart enough to realize what's happening here.
Main reason I replied to Tamago is b/c HE KNOWS the +35mm will rub when lowered (he was there when we rubbed the first time with our +35mm).
he also knows that a +23mm 15x7 doesn't rub on stock height but pokes a good amount on a YARIS (they were his wheels we used to test).
I wasn't trying to say he's wrong, b/c he isn't. He simply left out a small portion. :)
Old 01-31-2009, 06:15 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
i believe he was commenting on my comment about running a +35 on a yaris.
i personally run +23 front +(13) rear
Old 01-31-2009, 05:52 PM   #16
kimona
kimona's Avatar
To avoid rubbing problems with 205's, go with ET42 or higher.
Of course, on stock suspension you can run lower offsets... but the front set-up will poke and look like shit.
Like 39 says, this is a very fussy car for proper fitment. But, if you want the one-size fits-all American look, then go for it.
Old 02-01-2009, 08:37 PM   #17
FA7
Team Dynamics is way to expensive, plus they don't come to australia unless you import them yourself, hence very expensive!
Offset and lowering on 205/45/16s driver centric Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-13-2016 10:09 AM
How to determine proper wheel offset? Yaris Revenge Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 05-23-2009 10:41 AM
offset... Keymaster Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-01-2007 01:53 AM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
Max offset riceboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 05-01-2006 09:57 PM
